Computers & Internet Logo
Konstantino OO Posted on Feb 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant we update our bios of lgx110
Once i have inserted sd card in my lgx110 notebook when i inserted it my notebook become very slow so i directly pressed the power button to shut down and i restart it after that my notebook is always takes 4-5 minutes to load window but after load it works good .but the problem is it takes very long time to load window.some friends told me to update bios but i am unable to do so because i am quite unknown about this topic...so plz help me thanking u in advance
john smith
Level 2:
  • Expert 406 Answers
  • Posted on Mar 06, 2016
john smith
Expert
Level 2:
Answers
406
Questions
0
Helped
83935
Points
950
It;s not likely to be the BIOS. You've probably got a lot of stuff loading at startup
5 Related Answers
Tequella Chapman
  • 9 Answers
  • Posted on May 09, 2008
SOURCE: Toshina Satellite A135-S4527 Bios update, Problem after
Tyr this, turn your computer and just use your keys to select the control panel. 2 go into devices and see if your mouse is installed if the show s that your mouse is on there. Please select the mouse to refresh it. 3 Go back to the start menu shut down the computer for 2min the turn on strike the F12 key I believe and see if your mouse is installed.
Gav Shaw
  • 162 Answers
  • Posted on Dec 09, 2008
SOURCE: My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Anonymous
  • 2785 Answers
  • Posted on Mar 17, 2009
SOURCE: light blinking Dell LATITUDE C640
plz try by resiting the ram
Anonymous
  • 2517 Answers
  • Posted on Apr 11, 2010
SOURCE: i got problem with my acer aspire 3410, the system
Hi there please try these mentioned below.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
77141c2.jpg 2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Anonymous
  • 202 Answers
  • Posted on Jun 18, 2010
SOURCE: Upon pressing power button the laptop says to
yu need to reinstall your Operating system using the second repair console so that you wont loose your information. this will help. good luck
2helpful
2answers
Hi there I'm trying to update my Soniq tv because it's that far out of date it won't let me check for updates
Eventually the updates stop as the hardware becomes dated to any new software version. The idea is that you update the television.
https://www.google.com/search?q=s65vx15a-au+software+download
2helpful
2answers
Where to insert sd card
Normally the sd card slot will be on the side or in front of the laptop if it has that option. Not all laptops have sd card slots.
If your laptop does not have the sd card slot, then you can purchase a sd card reader that plugs into your usb port on the laptop for less than $20.
Try Tiger Direct at: http://tigerdirect.com
Below is a multiformat sd card reader for $9.99 at Tiger Direct.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=186067&CatId=2825
Also your camera might have come with a cable that plugs into the camera and the other end into the laptop's usb port. Once you have the cable connected, turn the camera on and the computer will recognize it. You can then search through the camera folder for the pictures or videos. If you use this method, you leave the SD card inside the camera.
1helpful
2answers
I have a jazz DVX50. The problem that I am having is I inserted the SD card and all it will keep reading is read card...
It is possible the card as become corrupted a common problem with cheaper SD cards.
2 Soulutions
1 Try reformatting the card in your pc by following the directions on the website below
http://www.ehow.com/how_4793481_reformat-sd-card.html
2 Unfortunately you may need a new card
2answers
VGN-N230N can not read SD card when install windows 7. (vista is ok)
Download all the windows 7 updates and install then restart. Windows update are not only updating your windows 7 but also updating your hardware driver. After updating try again your sd card or if still the same can not read try some memory card reader then test it to your laptop. Have a nice day.
2answers
Mmc sd card reader not working. i insert sd card nothing happens
http://www.medionusa.com/ Have you updated your drivers? i found some here. Hope this helps and good luck.-jmattes
Bios wipe
remove the backup battory inside or remove the laptop battery for about 2 weeks and the password shuld go
My SD Card Reader Won't Work, Need A Solution
Go here:
http://support.acer-euro.com/drivers/notebook/ex_4620.html
(The US server seems to be having problems right now)
Download the XP cardreader 2.0.0.8 drivers, install them. There are three possibilities to your problem:
1. The reader is broken
2. The reader's driver is malfunctioning
3. The reader has an issue that might need new firmware
4. All your cards have become currupted somehow (a malfunctioning device[IE camera]] or other reader, this is highly unlikely though)
Try the driver first, then if that doesn't work, then a motherboard bios update might help(but beware, this is a dangerous procedure, I wouldn't try this unless the update documentation specifically stated that it fixed an issue with the reader). I don't see an update for the firmware of the reader itself, so hopefully it doesn't need one.
Good luck
My notebook has graphic card by radeon xpress
hi..the reason to this problem may depend
upon the type of anti-virus u are using.once after
installing the anti-virus u have to keep on updating
it to a new update every day.This will solve ur problem
of slowing down.
check it out..
thank u..
Grand Canyon Tech
Grand Canyon Tech
