Hyundai 2004 Elantra GT Logo
T
Tyler D Posted on Feb 25, 2016
My climate control suddenly stopped working. Other than the under hood, and drivers side panel, is there another passenger side fuse box? Could it be a relay? Please see further details.
Climate control suddenly stopped working. Sunroof no longer opening. Auto wiper for washer fluid pull not engaging. Rear defogger clicks on but no power on light. No in cabin circulation. Checked the main fuse box, and driver side compartment box. A/C SW fuse not receiving power.
5 Related Answers
mastertecmec
Keith Hirsch
  • 42 Answers
  • Posted on Jan 25, 2009
SOURCE: blower fan
Sounds like the problem is more with the blower motor assembly itself. The blower motor have micro-proccers built itnto them which comunicate with the control heads and do the actual regulating of the fan motor. Dealers have computers with diagnostic software which allows them to monitor what is happening in the eletronic controls of the vehicle. Electronic diagnostics without the diagnostic software makes it very diffecult to pinpoint the actual item causing the problem.
Anonymous
  • 5 Answers
  • Posted on May 07, 2009
SOURCE: driver side windows on 08 elantra won't work
Take it to the dealer it's under warranty!
Anonymous
  • 12 Answers
  • Posted on Aug 05, 2009
SOURCE: Hyundai Accent 1998 Front Wiper and Washer Won't Turn Off
the black switches are master switches. They control stuff like the horn, the lights, wipers, AC, Engine Fans, and....there's one more that it controls, but i dont remember what it is. But you're going the wrong way about this. You're on the wrong side of the engine. You want to be on the opposite side of the engine, along the firewall, close to the front shocks by the windshield wiper motor. That's more than likely your problem. A little bit of water, grease, or some dirt might have slipped past the seal and caused a malfunction in the control wheel. Just open it up, clean it out, add some grease to the appropriate area, blow dry the circut board, stitch it back up, and that should solve the problem.
Please keep in mind that my American Car is a sligh bit different than your Australian Car. If the directions don't match up, i'm sorry for the inconvenience.
~Hope this helps
Anonymous
  • 382 Answers
  • Posted on Sep 21, 2009
SOURCE: Where is the fuse for the ac blower motor in a
dear friend the fuse that you are looking for is in the engine compartment,if you open the fuse box look to the right hand side,right at the bottom,there is a 40amp fuse marked BLR,that is your blower fuse
Anonymous
  • 176 Answers
  • Posted on Jul 11, 2010
SOURCE: 2003 Elantra GSL power windows don't work.
could be the driver side master window switch... if the driver side window switch assembly is broken then the windows will not work... try using a test light to see if you got power to the with and and ohm meter to check all four switches on the drivers side
Locate fuse for heater blower as it has stopped working
check under youre hood by the drivers side or passenger side wheel well there should be a black plastic box there open it up and on the lid there will be a diagram for youre fuses on the lid of it if the box isnt there it should be under the hood just under passenger side windshield wipers if not there the only other place that box or panel would be is on the drivers side near the emerngency brake petal or lever depending on what kind of vehicle you have
1helpful
2answers
I have a 1998 chevy suburban. The dome lights don't work. checked fuse box under hood. All good. Are there other fuses on the truck?
Instrument Panel Fuse Block
The instrument panel fuse block access door is
located on the driver side edge of the instrument panel.
Pull off the cover to access the fuse block.
The vehicle may not use all of the fuses shown.
Fuses Usage
1 Rear Seats
2 Rear Accessory Power Outlet
3 Steering Wheel Controls Back light
4 Driver Door Module
5 Dome Lamps, Driver Side Turn Signal
6 Driver Side Turn Signal, Stop lamp
7 Instrument Panel Back Lighting
8 Passenger Side Turn Signal, Stop lamp
9 Passenger Door Module, Driver Unlock
10 Power Door Lock 2 (Unlock Feature)
11 Power Door Lock 2 (Lock Feature)
12 Stop lamps, Centre High Mounted Stop lamp
13 Rear Climate Controls
14 Power Mirror
15 Body Control Module (BCM)
16 Accessory Power Outlets
17 Interior Lamps
18 Power Door Lock 1 (Unlock Feature)
19 Rear Seat Entertainment
20 Ultrasonic Rear Parking Assist, Power Liftgate
21 Power Door Lock 1 (Lock Feature)
22 Driver Information Centre (DIC)
23 Rear Wiper
24 Cooled Seats
25 Driver Seat Module, Remote Key less Entry System
26 Driver Power Door Lock (Unlock Feature)
2answers
2helpful
3answers
Where is the fuse box located
should be one fuse box under dash on driver side and one under hood!
1999 limited dual climate atc panel on dash wont power up
Solution to you examine the fuse for your climate control in fuse panel both under the driver side dash and in power distribution box under hood.A diagram is detailed remove the located fuse and inspected if blown replace with the same amp fuse.
The driver's side control panel won't work. i.e;
There's a 50 amp fuse in box under hood. Could be the problem as far as I can tell there are no fuses in car. Check all connections. This just happened to my car. I tried using my passenger side panel an drivers side and drivers side window starting working. I put the drivers side panel on the passenger side and all other functions worked except my initial problem. I found my main auto switch on drivers side panel was bad which was causing all other functions not to work.
3helpful
2answers
How do I open the fuse box under the hood? Are there any other fuse boxes?
theres 3, one under the hood, 2 inside the vehicle ..the interior fuse boxes are on the sides of the dashboard on both drivers and passenger sides. open the doors and look for the removable panels on the dash between the drivers and passengers dashboard.remove the panel....u will see the 2 interior fuse boxes...these 2 interior fuse boxes house the vehicles multiplex control units..
2answers
Power windows stopped working
Have the Body Control Module tested, this is the central. control for all the power windows.
2answers
2helpful
2answers
1998 buick park avenue drivers side blows cold, passenger side hot
sounds like the drivers temp door actuator is not working should be located on the drivers side of the air box down by the gas pedal or center dash area
Top Hyundai Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
