RCA RCU404 Remote Control Logo
T
Timothy Fields Posted on Feb 23, 2016
What are codes to program de(v)ices? - RCA RCU404 Remote Control
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
¿C?mo puedo saber el c?digo de mi unidad de potencia para escribir en Sy.3. Y c?mo ser capaz de cambiar el valor, ya que me marca error de sobrecorriente.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sumsung top loading washing machine error code de
Samsung use 'de' as the code for door problems,
Usually indicates that the door is open (or the program thinks it is !!)
I have a tfhw24 whistling ge refrigerator and the ice maker is not working. water is not entering, nevertheless the filter is connected to the appliance.
Since this is an older model it would not hurt to replace both the=> WR57X10051 Water Inlet Valve and the=> Ice Maker Assembly WR30X10093 To test feel the ice slots for any remaining cubes if no cubes of ice are there fill the ice maker to the near top and allow to freeze. If after the water is frozen the ice maker cycles and drops the ice in the ice bucket and does not refill with water change the water control valve. If the ice maker does nothing while there is ice remaining in the ice slots replace the Ice Maker
Appliance 911 Sea Breeze
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
4helpful
2answers
How to unlock LG DV 642 DVD region code??
Para Convertir el DV642 de LG a multiregion:
1- Enciende el DVD
2- Abre la bandeja de el DVD
3- Presiona el boton "0 (Cero)" 3 veces dejando entre cada vez que presiones el cero 1 segundo de por medio asi 0-0-0 donde el "-"es un espacio de 1 segundo despues preciona el boton 0 para fijar la region a cero para ponerlo en multiregion
y presiona pausa para guardar.
Our window-type airconditioner never gets that cool and when we remove the front cover, its all covered in ice....what should we do ? thanks
Problem is most likely the de-icing switch, a thermostatic device which cuts of the compressor when the evaporator gets below a certain temperature -- the de-icing switch is not opening, the compressor keeps running and the unit ices over. With ice on the evaporator, air does not flow over it, and the unit does not cool the room.
More info, let me know.
Charlie
7helpful
5answers
Need codes for GE television
I dont have your exact model but if one of these codes should work
000, 008, 009, 011, 012, 027, 038, 068, 086, 089, 091
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
