Sony BRAVIA KDL-46EX400 46" LCD TV Logo
Daren Ali Posted on Feb 23, 2016
What parts are to be changed on my Sony BRAVIA KDL-46EX400 46 LCD TV when getting vertical lines on the screen?
Hi, I am having an issue with my Sony KDL-46EX400. Upon powering on, the system freezes and vertical lines appears on the screen. It is unresponsive to inputs from the remote and can only be turned off by pulling the plug. Can anyone advise as to what parts i should change?
ibrahim
Level 1:
Habit-Forming:
New Friend:
  • Contributor 19 Answers
  • Posted on May 05, 2016
ibrahim
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
19
Questions
8
Helped
2510
Points
31
Either lcd panel or t-con.Try t-con first because its cheaper.
5 Related Answers
Anthony Gonzales
  • 267 Answers
  • Posted on Mar 06, 2009
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Anonymous
  • 59 Answers
  • Posted on Mar 10, 2009
SOURCE: Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Anonymous
  • 157 Answers
  • Posted on Oct 05, 2009
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
Anonymous
  • 1284 Answers
  • Posted on Dec 02, 2009
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Anonymous
  • Posted on Apr 01, 2010
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Sony tv KDL-40S4100 vertical lines on right side
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
What board is defective on a sony bravia KDL-XBR6 that has a colored vertical lines on the whole screen? No pictures on screen an its just a colored vertical lines...
T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
3helpful
2answers
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
1helpful
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
3helpful
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
21helpful
Sony bravia kdl 32l4000 - color bars running vertically on screen
1helpful
Thin vertical line runs across the top of screen on my Sony Bravia KDL-32L4000
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
