Question about Motorola Waris GP328 GP338 GP638 Plus 2-way Radio power cord cable
I need software - Motorola Waris GP328 GP338 GP638 Plus 2-way Radio power cord cable
Posted by Asad Javad on
L Pfaff
    Top Expert:
  • Motorola Master
  • 11,573 Answers
Asad, re post your question, with the complete question,make and model #'s. and what software you require.
Posted on Feb 23, 2016
I can not down load Xfinity Stream app on my Samsung Galaxie Tab E. Need help. What could be the problem?
you need software to make that happen. Contact Comcast and ask them what software you need to download and install.
Sep 02, 2017 | Samsung Tablets & eReaders
Need to have flash on my samsung tablet. I downloaded the archived version . It still doesnt work
youll need to register at sam mobile to download software version
youll then need to download odin tool to flash new software to device
be careful
Nov 10, 2016 | Samsung Tablets & eReaders
How do I determine if I need to update my Kindle Fire?
Your Kindle Fire needs to be fully charged and connected to a Wi-Fi network before you can download the software update.
Tap the Quick Settings icon, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update.
Apr 16, 2016 | Tablets & eReaders
How do I update my kindle?
Didn't update in time? Do a manual update At this point, you'll need to update your device manually. It'll require you to grab a USB cable and do the install with your Kindle connected a computer. Here's how:
  • Go to Amazon help page, find your device and click the link in the neighboring column to download the update. Use the above instruction to find out which software your device is currently running. In some cases, you might need to download and install more than one update.
  • Plug your Kindle into your computer. Once it appears as a drive, drag and drop the update file to your Kindle. (Not a subfolder, just the top-level Kindle drive.)
  • Eject your Kindle and disconnect the USB cord.
  • On your Kindle, go to Menu > Update your Kindle. Your Kindle will let you know when the update is complete.
abcFileHippo Download Free Latest Update Software and Printer Drivers
Mar 21, 2016 | Tablets & eReaders
Has software rev 6.3.4. How can I determine whether it needs mandatory software update?
A new, free software update available for your Kindle Fire HD 7" (2nd Generation). This update automatically downloads and installs on your Kindle Fire when connected wirelessly; however, you can also manually download the software and transfer the update to your device via USB cable.
Swipe down from the top of the screen to open Quick Settings, and then tap More.
  1. Download & Install Software Updates Automatically.
Swipe down from the top of the screen to open Quick Settings, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update. After the restart, the message"Kindle is upgrading" will appear on the screen.
Mar 19, 2016 | Amazon Kindle Fire HD
I purchased a iPad4 on eBay it is locked do you have the the software to unlock it
I presume the iPad turns on normally and works. You just want to unlock it to be able to install non-approved software. In that case you need to JAILBREAK to unlock the iPad. Yes you need software to Jailbreak, and software to back up data, plus you need step by step instructions you "must" follow exactly in order for the Jailbreak to be successful.
Since each IOS requires a specific program, you must search for a program which does an iPad4 plus the IOS on the iPad. Finding a jailbreak is quite simple by entering in Google Search "Jailbreak for iPad 4" that's if a jailbreak exists for your specific iPad.
After hitting a few sites and reading carefully you should be set.
May 10, 2014 | Apple iPad 64 GB 3G Tablet PC
Doea anyone know how to unlock activation lock ios7 for ipad mini?
yes but its probably your itunes software at fault. un install the itunes software and apple drivers from the pc restart pc. then download a fresh itunes and when it is installed try it again Without the virus software on turn it off should activate then. then you can turn back on anti-virus software. you also use ccleaner free down load and clean your pc/laptop and after the restart clean the reg files with this software it will remove old files that are not need any more or are causing conflicts. uninstalling itunes does not remove your items you have just the itunes software everything ells will be stored on the pc/laptop e.g contacts apps etc. they will not be lost
May 09, 2014 | Tablets & eReaders
How to i get the touch screen working
The touch screen function is controlled by software and drivers. You'll need to start by making sure that you have the correct tablet software installed on your machine, and you may also need the correct WACOM drivers.
You can go here and download the software for your tablet and see if this works for you:
http://www.wacom.com/downloads/drivers.php
Mar 04, 2010 | Gateway M275 Tablet PC
Motorola Waris GP328 GP338 GP638 Plus 2-way Radio power cord cable Logo
57 people viewed this question
Top Motorola Tablets & eReaders Experts
buddyglee
buddyglee
Marvin
Marvin
ray gallant
Are you a Motorola Tablet and eReader Expert? Answer questions, earn points and help others
