Question about HP Computers & Internet
My hp 2000 notebook pc widows 8 when i turn it on. It has 4 blue line thats all it does
Posted by Shonda Mccoy on
Larry Ng
  • HP Master
  • 6,445 Answers
WOW THAT IS ONE HUMDIGGER OF SCREEN .
OFF AND BAD LCD?
does BIOS pages do this?
esc key or f10 power on,hammer the esc on newer pc
and bios info page shows up clean, or F10 old PC
if not bios clean the LCD is bad or is 2007 lead out BGA solder ball failed GPU chip
hp 2000 is 2011 made so is not 2007 horror year, good that.
learn now to use BIOS. esc key is it.
then at that page it tells you other keys, F1 ,f2 etc.
any page full is what you want INFO page BIOS.
Posted on Jan 14, 2022
4 Related Answers
Anonymous
SOURCE: When I turn it on, there are blue lines that run down the LCD
There is a loose connection on the screen you need o call in an repair man.
Posted on Jan 06, 2008
Anonymous
  • 194 Answers
SOURCE: HP Compaq Presario V6101US Notebook PC' push the
There are several reasons why this could be happening. Below are a few diagnostic steps we can start off with to eliminate some possibilities. If there is anything you are not comfortable with doing yourself please consult a local repair technician.
  • Remove the battery from the system and try booting up the computer with only the power cord. The "1" in the diagram below is the battery, "2" is the battery release latch.
  • Try removing one of the memory modules (if there is more than one) from the system by following the below steps.
1. Flip the computer upside down. Remove power cord and battery and ensure the system is completely off.
2.Unscrew the compartment labeled "4" in the diagram below. This is where the battery is held, as well as the WiFi card and motherboard battery. DO NOT do anything to these other components as they are quite fragile.
3. If there is more than one memory module you should remove one. Replace the compartment cover and attempt to boot up with battery and power cord reattached. If nothing has changed try swapping out the memory with the one you just removed.
If still nothing happens, this is not the issue. Comment back and we will move further with your case.
Good Luck,
NOLA Tech
Posted on Jan 28, 2010
Anonymous
  • 10 Answers
SOURCE: HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
Posted on Aug 13, 2010
Electronics Repair
  • 452 Answers
SOURCE: Describe your HP Pavilion dv9000z
This is very common for the HP dv9000 series laptops. The problem is the controller chip. You can either do a reflow or replace the motherboard.
check out the DIY guide from www.net2005.com if you wan't to try fixing it yourself. Or get your self an USB wireless card and problem solved.
Posted on Oct 29, 2011
How do i fix black screen on a HP 2000 notebook PC running Windows 8 ?
graphics failure is the common cause,is warranty repair an option?
1helpful
How do i disconnect my cannon powershot A4000 IS from my hp G56
if your computer is widows vista, 7 or 8, you no need to expect any notification. after finishing all your transfer just plug out after few seconds.
2answers
Hp Presario 2000 will not get to windows sign in
Do you see an error message on the screen or, does it blue screen with an error message? When you boot up press F6 just as the PC drops out of BIOS mode. Select "Last Known Good Configuration". If that doesn't fix it, look up the error code on the blue screen with Google. Most blue screens are fixable. Some require a complete rebuild of your hard drive.
Blue Screen hardware error on new HP g series notebook pc
It appears you have a faulty notebook. This can happen if the notebook come from the same batch of units that could be faulty.
I suggest you return the notebook to the store and get it fixed under warranty.
2answers
Hp pavilion dv 2000.Screen will not light up and I cannot hear any noise from the drive. Blue lights accross the top all are lit.
Perform the steps below :
1. disconect the ac adapter and remove the battery from the notebook.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. Turn On the notebook
If the issue persists then reseat the memory modules of the notebook and check
This should resolve the issue
However, if the issue persists then it could be a hardware issue. Your notebook needs to be serviced
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
