Question about Chevrolet 1995 Chevrolet S10/s15/sonoma Radio
4.3 vortec engine start ideing to fast wont stop
Posted by Paula Quinn on
Lawrence Oravetz
  • Chevrolet Master
  • 10,543 Answers
Check the idle control module for proper operation. A diagnostic est will throw a code if it isn't.
Posted on Sep 10, 2016
Why is my radiator fan running fast?
Check the thermistor controlling the fan.
Jun 10, 2018 | Mercury Cars & Trucks
99 gmc sonoma wont start
Engine cranks (Turns over) & will NOT start ??
Engine will not crank (Turn over) ??
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
Feb 21, 2014 | 1998 GMC Sierra
1996 jeep wont stay started and oil pressure gauge goes up and down
hot or cold engine , or both.?
the oil pressure will be in direct ratio to engine rpm. slow low, fast high
due to the oil pump connection to engine crankshaft.
stalls.: can be caused by 50 things, or just 4 in physics.
the EGR valve (if you have one, no engine stated)
can stick open and stall any engine, and in fact LOVES to. clean it.
1: list 12vdc to EFI. (spark and fuel brain) dash lights dim?
2: lost compression hot, ? compression tests.
3: lost spark, do spark tests. and timing, checks.
4: bad fueling, too much if floods, and misfires and stalls.
too little fuel, it starves and dies.
the 1 free test, is can you save the stall with a fast right foot.
we do the tests. avoiding those 50 guesses....
each tests are simple and the tools dirt cheap .
Jan 30, 2014 | Jeep Cars & Trucks
Control box
try replacing the relay that is clicking
May 25, 2013 | 1992 Honda Accord
I have a 98 s-10 it wont start it has 40 to 45 pounds of pressure & its firing getting gas but wont run i pulled the fuel pump relay n it try to run i sprayed it with start fluid it hits but if i put...
If this truck has the 4.3L vortec motor it will not start with 40-45 PSI fuel Pressure.Thius engine requires approx. 56 PSI fuel pressure or it will not start. The fuel pump more than likely needs to be replaced this is a common problem with the 4.3L vortec engine.Change the fuel pump and your problems will be solved.
Apr 26, 2011 | 1998 Chevrolet S-10 Pickup
1996 gmc k1500 4x4 5.7 vortec motor no start keep
Replace the coolant sensor on the front of the intake manifold.The coolant sensors on this engine does go bad and wont set a check engine light. The sensor will read about -32 to 0 degrees when they do go bad. The computer thinks it is that cold and sends tons of fuel to the engine. If you try to start the engine with the throttle depressed to the floor it puts the fuel system in clear flood mode and wont fire the injectors. Engine will start then and run very rich. The coolant sensor has two wires on it and sometimes you need to replace the wiring pigtail going to it as the sensor can seep coolant into the connector and corrode the terminals. All the parts are available at pepboys and autozone or napa. Good luck
Jan 05, 2010 | 1996 GMC Sierra
Replaced head gaskets upper lower intake gaskets now wont start 96 vortec
Is it even trying, backfire, crank real fast. Or just won't start at all no matter what you do? Also is the gas good?
Dec 18, 2009 | 1996 Chevrolet K1500
1999 chevy blazer wont start
THE FUEL PUMP IS BAD.
if your losing fuel pressure after the pump runs the drain back valve in the pump has failed.
and i doubt that you are seeing enough fuel pressure to run a vortec engine.
low fuel pressure equals a non running vortec
Apr 11, 2009 | 1999 Chevrolet Blazer
Cold starting problem
hi if its ok when warm its the cold start system check the ecu,s engine temp sensor first and if ok check the fast ide cold start solenoid . yates210456
Oct 26, 2008 | 1998 Chevrolet Blazer
Chevrolet 1995 Chevrolet S10/s15/sonoma Radio Logo
474 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
