Big buddy heater, push the control knob, click to light the pilot, hold for a minute or so, let off the knob, pilot goes out. Second heater did the same thing, using a 20 lb. tank with a inline filter
Inline filter? Did you mean inline regulator?
Sounds as if the Oxygen Depletion Sensor (ODS) may be clogged with dust and lint. You will need to open the heater to access the Pilot Assembly (the ODS is part of the Pilot).
Once you have done this, use canned compressed air with a straw nozzle attached (like you clean your computer with) to blow out the pilot tip (just a quick shot of air please. Then look down the pilot from the flame tip and you will se a small hole in the side of the pilot. That's the ODS sensor. Place the straw nozzle just barely into the hole and give it a quick shot of air. That will blow any debis out of the ODS sensor. Any other dust, lint and/or pet hair you see inside the heater should be cleaned out.
Once you have done this, if the heater will allow it, light the pilot as usual and see if it holds after releasing the control knob. If holds, great! If doesn't, relight and hold the control knob in and look at the pilot flame. Is it curling up and away from the Thermocouple? If so, try cleaning the pilot again. That should solve your problem.
If it still won't hold after it's lit, you will need to replace the Thermocouple.
Hope this helps to get the heater working again.
