Dvd door will not open
JVC HR-XVC27U door on the dvd side wont open and when the open/close button is pressed the screen shows "LOC" but when it isnt pressed it shows "READ". What do I need to do or do I need to take it to a repairman to get the door unlocked.
Posted by terry1990 on
  • terry1990 Nov 18, 2007
    it unlocked it but it still wont eject the dvd
Soulvisitor
  • 1,113 Answers
Tray Lock
You can lock the disc tray to prohibit the unwanted disc ejection by children.
To lock the disc tray.
While the unit is turned off, press and hold 8, then press x on the unit. “LOCK” appears on the front display panel and the disc
tray is locked.
To unlock tray
While the unit is turned off, press and hold 8, then press x on the unit. “UNLOCK” appears on the display panel.
download user manual by clicking HERE
Posted on Nov 18, 2007
  • Soulvisitor
    Soulvisitor Nov 18, 2007
    Did display indicate unlocked after pressing stop and eject power off/on, if it did and still wont eject after pressing eject button than it needs repair shop or screwdriver tactics
  • Soulvisitor
    Soulvisitor Nov 20, 2007
    We fixed it and he ran away!?
Mitch
  • 752 Answers
With the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
  • Mitch
    Mitch Nov 19, 2007
    Now that it's unlocked, try unplugging it for 5 minutes then plug it back in and try to eject the disc. Report results here.
Is ther an HDMI cable for JVC xvc27u
There is no HDMI OUT socket on this player. I don't enjoy giving negative answers, so if you could explain why you want to use an HDMI cable with this player, I can possibly make some suggestions which will help you to achieve whatever it is you are trying to do.
If you were simply looking to buy this or any other player and want one with an HDMI output, you should look for something else ;)
Hope this helps.
Feb 15, 2011 | JVC HR-XVC27U DVD Player/VCR
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Dvd will not eject from jvc hr xvc27u dvd player all it will do is display the word read on the screen
elsombro is right. There is a little whitish plastic square on the right side of the player, part of the DVD assembly (after you take off the cover). It's about 1/4 inch square. With the unit turned on, push that square with a pen about 3/4 of an inch in or as far as it will go. There will be a clunking sound but that is the sound of the DVD being released back onto the tray. Now gently push the back of the tray forward, ejecting the disk manually. Take the disk out and then press the close button. If the door doesn't close, it's out too far so manually push it in about an inch or so and then press the close button again. Should be fine after that. I think my problem was a DVD I recorded on my computer and it has the wrong format or something. After I got it out I put a regular DVD back in and everything was fine.
Dec 30, 2009 | JVC HR-XVC27U DVD Player/VCR
Does the JVC HR-XVC27U play multi-region dvds?
It’s capable of playing REGION1 disks and disks that marked as ALL REGIONS. It will not play any other disks.
Dec 02, 2009 | JVC HR-XVC27U DVD Player/VCR
My jvc dvd player/vcr will not eject disc says its reading but wont play or eject
You might want to check the thin ribbon cables attached to the dvd inside the unit, pull them out and slip them back in.
Nov 24, 2009 | JVC HR-XVC27U DVD Player/VCR
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
Need users guide
please click or copy this link http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man follow the download instruction... enter your email ad, and numbers shown below then click download now. if this doesnt work, let me know. thank you for using fixya and help us by posting your comment.
May 02, 2009 | JVC HR-XVC27U DVD Player/VCR
Region 4 videos
What your friend needs is a region hack...Go to www.videohelp.com have your friend put in the model number, hit search, scroll down, look to the right. If any one has a hack for this they do.
Jun 30, 2008 | JVC HR-XVC27U DVD Player/VCR
DVD will not eject from JVC HR-XVC27U
Disconnect the Power Cord. Open the Case and go to the DVD unit. On the right side of the unit you will see an indentation which is the mechanical portion of the DVD Unit.
Push the indentatation in, it is the eject switch. The DVD unit door opens remove the DVD stuck in the unit.
Put cover back on plug the unit in, insert a workable DVD and all should be OK.
The problem was the unit could not read a Defective DVD which I made and the unit was locked in to reading the DVD.
I hope this helps
May 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Televison & Video Logo
705 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
