When i turn on tv i have a black screen
How do i know if it is the t-con, controller or any other board
Posted by Rick Wagner on
L Pfaff
    Top Expert:
  • Televison & ... Master
  • 11,573 Answers
I have a Vizio E421VA LCD HDTV and am getting a black screen. The power light comes on, but am still getting a black screen. Does anyone have the same problem and/or solution?
To determine if the backlight driver or the T-Con board is the problem, di this. With the TV on shine a flashlight on the screen. Look for a faint picture. If you can see one then the backlight control board is bad. If you see no movement or any picture at all, the T-Con board is bad. You can get the parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 17, 2017 | The Video Game Consoles & Games
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi Televison & Video
I have a Samsung tv pic does not work but have sound..model #40pfl3705D/f7. What part needs replaced...t-con board?? And if it is.. how do I know which board is t con board?
Here's how you determine if it's the T-Con board. Turn the TV on and shine a flashlight on the screen. If you can see the program you're hearing then the T-Con board is OK. The inverter board controls the back lights. This board is the problem.
Mar 25, 2015 | Samsung Televison & Video
Half screen black
First thing I would look at is the t-con board it is located at the top of the tv and controls both halves of the screen. Also make sure all voltages coming from the power supply is good as well. You should be able to find another t-con board on ebay or shopjimmy dot com.
thanks,
michael
Dec 10, 2011 | Panasonic TCP42S2 42 in. TV
My TV are blisting of left half display or black out of that. Hit or pressure on the back make sometimes full display well.
Hello
It is due to some loose fixation with its flat cables that connected to lcd disply screen to its T'con board. T'con [Timing Control] board is the driving board to LCD display. If there is some loose contact, the fault you describes here can occur. Just open the TV, and detach and reattach each flat cables that connects with T'Con board ot LCD screen. This must solve the probel of your TV. OK.
Nov 23, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
Westinghouse tx-52F480s. flicker, turned into colored lines. now all black. all inputs. what is the problem. which board?
Most likely the T-CON board it is dead.The tv have colors vertical lines alway causes by a dead T-CON board,if only this problems,happen by the tv itself only.Not causes by u or an object by hitting it with forces,than the tv LCD screen panel it is damages and tv it is worthless as a whole tv set.Because the tvs LCD screen panels are very important to the tvs and it is 90% of the costes of all tvs.The T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 13, 2011 | Westinghouse TX-52F480S 52 in. LCD TV
When we 1st turn on the tv the left half of the screen is black right down the middle of the screen,,,,then 15 mins or so it starts to slowly regain strips of color and finally it has a full picture! Then...
When tv it does have a full picture,the tv it work ok?Yes,tv it is repairable.This tv problems are only have two possible electronic boards causes.1 the tv board that call the T-CON decoders board it is dying,this board sit in the middle of the bottom of the LCD screen panel,it control and decoding all the picture dots pixels before it gose into the LCD screen panel.2 worst cases the main board the tv Tuner signal board is it dying,this board control everythings.Like it take in the outside incomming signals sources,like the tv incomming broadcasting signal cable wire and all the external electronic unit divices plug it into the tv.80-90% this tv problems it is the causes by the tv T-CON decoders board only.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish T-CON decorders board and the tv main board Tuner signal board for the replacement.
May 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Tv screen goes black.
t-con board board failing or the cable needs reseating, meaning unplugging and putting back on a gain. t-con board is the one screwed to the back of the screen with a metal shield covering it.
Feb 01, 2018 | Televison & Video
Televison & Video Logo
1,822 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
