If your Onkyo TX-SR602E receiver is stuck on the CD input and doesn't change, there could be a few possible causes for this issue:
1. Input Selector Issue: The input selector switch or button may be malfunctioning or stuck. Try pressing the input selector button repeatedly or cycling through the available inputs using the remote control to see if it frees up and allows you to change the input.
2. Remote Control Issue: If you're using the remote control to change inputs, it's possible that the remote control itself is not functioning correctly. Replace the batteries in the remote control and ensure that there are no obstructions between the remote control and the receiver's sensor.
3. Signal Connection Problem: Check the audio cables connected to the receiver's CD input. Ensure that they are securely connected and not damaged. Try using a different set of cables or connecting a different audio source to the CD input to see if the issue persists.
4. Internal Circuitry or Software Issue: If none of the above solutions work, it's possible that there is an internal issue with the receiver's circuitry or software. In this case, it may be necessary to have the receiver inspected and repaired by a qualified technician.
5. Reset the Receiver: Try performing a factory reset on the Onkyo TX-SR602E. Consult the receiver's manual for instructions on how to perform a reset. Please note that a factory reset will erase all custom settings and configurations, so be sure to back up any important settings before proceeding.
If the issue persists after trying these troubleshooting steps, it is recommended to contact Onkyo customer support or consult a professional technician for further assistance. They will be able to provide more specific guidance and help resolve the problem with your receiver.
To perform a factory reset on a Yamaha RAV 352 remote for use with an RX-V2500 receiver, follow these steps:
1. Turn on the RX-V2500 receiver using its power button or remote control.
2. On the remote, press and hold the "VCR 1" and "ON/STANDBY" buttons simultaneously. Hold both buttons for about five seconds until the remote's indicator light blinks twice.
3. Release the buttons. The remote control should now be reset to its factory default settings.
4. Test the remote by using it to control the RX-V2500 receiver. Make sure the remote is within range and pointed towards the receiver's IR sensor.
If the factory reset doesn't resolve any issues you're experiencing with the remote control, you may need to try replacing the batteries or consider getting a replacement remote from Yamaha or an authorized dealer.
Please note that the steps provided are based on general instructions for Yamaha remotes, and there might be slight variations in the specific procedure for your RAV 352 model. Consulting the user manual for your specific remote or contacting Yamaha customer support can provide you with more accurate and detailed instructions tailored to your device.
Personally I would replace receiver located under ceiling canopy. This will require electrical wiring, and is best left to experienced electricians. If you look in the instructions that came with fan you will see the receiver and part number. However you can google your fan model number + receiver for several to choice from.
I suspect remote is unable to communicate with the base and is reporting the issue as power loss at base.
So does the base function, makes and receives calls?
Reset the base unit and power supply by unplugging the base power supply from the wall, wait at least 1 minute, plug base power supply back into wall outlet.
Reset remote by removing battery wait a minute, reinstall battery.
If after the reset the base can't make/receive calls, its likely failed.
If the base works and the remote still reports base power issue, could be either base or remote.
Google the model number of the remote for "manual" which if found will provide instructions and a POSSIBLE list of codes to try--not all remotes will program for all units...........
Google the model number of the remote for "manual" to try to locate one which will have instructions and a list of POSSIBLE codes--not all remotes will program for all units............
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work. You can remove the battery from the slave remote units to reset.
1. Open battery compartments of all remotes and the base unit. 2. The following steps must be completed within a small time window of a minute or two. 3. Remove and replace one battery from the base (reset button on base may also work) 4. Remove and replace one battery on first remote. 5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base. 6. Remove and replace one battery on second remote. 7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1. 8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
