M
Margaret Winifred thomson Posted on Feb 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wish to clean rollers - OfficeJet HP Office Equipment & Supplies
Davy Smith
Level 2:
Habit-Forming:
New Friend:
  • Expert 74 Answers
  • Posted on Mar 06, 2016
Davy Smith
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
74
Questions
Helped
11911
Points
122
Try using baby wipes, I know that sounds funny but it does work or get some isopropal alcohol from a chemist.
My printer say "out of paper" but there is paper in it. It worked fine just yesterday
Try to clean the paper try and input roller.
If you wish to get some more details about printer repair then check the following link.
http://electro-medical.blogspot.com/
3answers
Canon ir 7095 copier ADF too much paper taking in one time.
Check the paper thickness. It can be a problem. try with another paper.
If you wish to get some details; check the site linked here. Pull up older posts.
I wish to clean rollers
Go to an office supply store and ask for printer cleaning sheets. These are heavy paper with a sticky substance on both sides. You run it though the printer a couple of times to pick up the paper dust off the rollers and the paper path in the printer.
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
2answers
How do i clean the rollers they are leaving streaks on the paper
Hi, after you power on and printer is ready to use, enter the setup, scroll down to maintenance, click on this maintenance and wait for minutes for the printer to do all necessary cleaning on the printer that you need.
I wish you best of luck.
3helpful
Hello! i have a samsung dvd vcr combo. 4 yers old. the vcr eats my tapes and pic is jumpy. what can i do to fix?
HELLO
You have a Tape Path problem here. There a few causes but I think the main one is the pinch roller may be worn/mis-shaped or even dirty. You need to have the tape path cleaned totally first and to try the deck again (has it been serviced/cleaned in four years?) If it still has the problem you will then need to have the pinch roller replaced.
There is also the possibility that the VCR deck may be developing a mechanical fault.
I wish you well with it. (:-)
1helpful
Rollers on Pixma 2600 won't pull paper through
Unfortunately you have come to a dilema of the printer world. The rollers are mearly chunks of rubber, expected to last forever and pick up pieces of paper. Every time a piece of paper is picked up, it drys out the rollers, and dust covers the rollers. Here is a temporary solution.
Temp Solution: Open the printer, look for rollers, you will likely find several small black in color, rollers. You may see cracking, or white powder on the rollers. Even if you don't, here is your solution. Take a damp paper towel, and wipe each roller thoroughly. Make sure you look all around to make sure you are getting all rollers.
Longer solution: Purchase a maintenance kit for your printer. I know HP carries them for their printers (HP is the way to go with printers). They will include rollers, and little tools to obtain the rollers along with detailed instructions. If they do not make one, find one broken on ebay for 12 dollars and get that. The kit would have cost you between 12 and 30 dollars anyways.
I wish you the best of luck. Please e-mail me if you still have issues. [email protected]
Roller Marks on HP Color LaserJet CP 3505
Hi rachel179:
You need a Repetitive defect ruler to determin the
cause and location of the problem. I will send it to you if you wish me to.
[email protected]
The printer is moving - just extremly slow. We haven't used it in weeks because of this. I have unplugged and plugged in a few times. It does not say that the ink cartridges are empty. Psc 2100
It need cleaning thoroughly, clean its Toner/Cartridge and internal part of Printer viz. Roller, Carriage Rack, and if you wish go for its Service. Let me know in either case, before voting me.
2answers
2400w Konica Minolta Magiccolor
dont understand your problem quite well, but, for a connection problem, update driver, change usb cable and last if nothing helps, update firmware.
for a paper take up problem,:
turn off printer,
remove cover,
remove drum cartridge,
under that there is take up roller, pull the knob and move the roller to right, then you can pull the take up roller out.
first try to clean it and also clean plate under the take up roller. if thats not helping, then you have to cut the biger (larger) plastic sides of the take up roller a little smaller..
should help.
good luck
k24674
Grand Canyon Tech
Grand Canyon Tech
