Question about Riccar Vacuums
How do i replace the fan on a riccar rsl3 vacuum cleaner?
Rsl3 model riccar vacuum - The fan/impeller has broken in pieces and I need to replace it. Should I also replace the fan housing and the belt at the same time?
Posted by Cathy King on
Pieter Vleeshouwers
  • Riccar Master
  • 2,020 Answers
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Posted on Feb 23, 2016
How do I replace the handle on a riccar rsl3 vacuum cleaner
Remove the screws holding the cover that holds the handle in to remove the handle. Reverse the procedure with the new handle.
Jun 18, 2017 | Riccar Vacuums
Why does the belt on a riccar vacuum keeps coming off?
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
Feb 04, 2017 | Riccar Vacuums
What kind of screw assembly is needed for the top cord holder piece on the Riccar 8900 vacuum cleaner?
There is an L shaped bolt that inserts into the hole in the handle, there are washers, a spring and a nut. I have all the items in my retail store. Most Riccar dealers will stock the items you may need.
Aug 25, 2014 | Vacuums
How to change belt of riccar vacuum rsl3
Remove the bottom plate after laying the vacuum upside down, make sure it's not plugged in first. Pull the brush roll out of the nozzle housing, put the new belt around the motor shaft and then the brush roll, pull on the brush roll to give you enough leverage to install the brush roll back into place, reinstall the bottom plate.
Jun 06, 2014 | Riccar 8955 Upright Vacuum
Vacuumed a paper clip up in my Riccar vacum cleaner
It depends on which model and where the clip went. On most models it will just suck the clip right into the bag causing no harm to the vacuum. If you can't find it and don't hear any funny noises it probably will not cause any harm. You can have it checked out by your Riccar dealer to be sure.
Mar 30, 2014 | Riccar Vacuums
Riccar rsl5 motor fan impeller replacement
From your local Riccar retailer.
Dec 01, 2013 | Riccar Vacuums
Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
Apr 13, 2013 | Riccar Moon, Pazza Vacuum Cleaner...
Broken handle riccar radiance
Take the broken part to your Riccar dealer. The newer models have an upgraded more durable handle. You can get the upgrade for an older model.
Mar 25, 2013 | Riccar Radiance Vacuum Cleaner HEPA Filter...
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Riccar 8850 Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at [email protected].
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Vacuums Logo
226 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
