When I turn my brand new air purifier on on it smells like its burning or going to catch on fire is it supposed to?
I just bought my quietclean hfd140 and after checking to make sure the filter was not in plastic i plugged it in. it smells like it is going to catch on fire. is it supposed to.
An expert that got 20 achievements.
An expert that got 10 achievements.
An expert that got 5 achievements.
Honeywell Master
Re:
That unit is a very heavy duty machine that uses ionization to clean air. There is a high voltage power supply that is used to generate ions. The unit can release ozone and that substance has a definite smell to it. If you have ever been near a copy machine or an electric motor that sparks, you would smell ozone. The concern is whether or not it is ozone. Ozone is regulated by the manufacturers to be held at a permissible level because at high concentrations it is an irritant and can cause respiratory issues by itself. The power unit for that air cleaner is on the top near the back and you can run the machine for a while to see if that area gets hot. That would be a bad sign. All the documentation is here: http://electronicaircleaners.com/f50f1032parts.aspx But if you don't trust the unit, take it or send it back.
am sorry to disappoint you, once this condition is reached, it means the motor windings have overheated and your motor needs to be replaced, This is the only best thing to do to rectify this situation. This indicates that the insulation covering the wire used to make the winding of the motor has been cooked by the overheating and it is shorting out ,THIS WILL CAUSE THE MOTOR CATCH FIRE.
Please unplug the unit and have the motor replaced or buy a new unit for your safety.
? 1:22
www.youtube.com/watch?v=gWB121JIQMw
Apr 28, 2011 - Uploaded by Bill Golden
Overview of damage and possible fan problem with Honeywell Air Purifier. ... Honeywell QuietClean Compact ...
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Manual can be found here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=47a366c04a65e77c69850893b979e142
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
