Question about Panasonic Lumix DMC-FZ8 Digital Camera
Why was DMC-FZ8 made so when in the"Motion Picture Mode" focus, zoom and aperture are fixed at the initial setting? Must now choose blurry or broken (start-stop/focus-restart...)video & sound.
I am using my DMC-FZ8 for documenting neighbor noise problems. If I want to be able to see clearly as the subjects move I need to refocus and reset zoom as I follow the action. The only way I can do that is to stop recording, change the focus and zoom and then restart. By the time I've done that the subjects have moved and are out of focus. This also creates broken audio stream which makes the whole thing look like a poorly created photo (video)-shop project and, if needed for court would not be considered good evidence. I also do some amateur photography (and I would like to do video) at motorsports events. Being able to work with one camera would make my job so much easier, but in motorsports one must be constantly refocusing and re-zooming. I know the answer is to get better equipment, but right now I haven't the funds to upgrade. Is there anyway to reprogram the FZ8 so that those adjustments can be made without having to stop?
  • Anonymous Mar 06, 2016
    Sorry I didn't vote sooner. Thank you for the answer. It is very helpful. I am doing what you advised and it is making it easier.
    Thank you again for the HELPFUL answer!
    Kenn Dillon
Lawrence Oravetz
  • Panasonic Master
  • 10,548 Answers
Unfortunately no. You can get better video if you turn off auto focus and set the zoom position to the halfway mark . This set up will significantly improve your results.
Posted on Feb 21, 2016
Telephoto opteka instructions
There are several reasons why you have to use this lens in manual mode. There is no chip in it and no focus motor. But even if there was a focus motor, your camera could not focus automatically, because the highest lens opening (smallest aperture number is f/1:8 on 1300 mm it is even f/1:16) Your camera only can focus on AF if the aperture is or is smaller than f/1:5,6. For the rest, you should chose the M on your mode dail. and then you can just press the shutter release button. Look on the screen how the histogram looks. If the histogram is to the left, the picture is to dark, so you should choose a longer exposure, if the histogram if far to the right, the picture is to light, so you should choose a shorter time. Have fun.
Nov 24, 2013 | Cameras
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
How can i take black and white photo with panasonic dmc-fz8
in the rec/motion picture menu, go to "color mode"....there is a setting for "B/W".
Dec 03, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Hi i have a Panasonic Lumix DMC-FZ8. How do I
This should help
Press [ menu set] to display the [PLAY] mode
menu and select the item to set.
You can copy recorded picture data from
the built-in memory to a card or vice versa.
1 Press up/down to select the copy
destination: (in to card) and then press
[MENU/SET].
Jun 17, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
My pictures turn out blurry
try using a camera tripod or leaning against something sturdy, like a building or tree, especially when really zoomed in! As the light dims, the camera will choose a slower shutter speed and/or wider aperture (in automatic) to produce a picture that is not too dark. As a result, the camera may take blurry pictures, especially if the camera or subject moves. There is a setting for landscape, which uses a very small aperture, and just about everything from close to far away can be in focus. Hope this helps!
Oct 16, 2009 | Canon PowerShot A560 Digital Camera
Wont zoom in or out message reads turn the power off and on again can access stored pics but wont take new ones sony cybershot dsc w35
Is this camera only have a digital zoom? If it has an optical zoom as well, you could have a setting that is set to ignore digital zoom and because your lighting conditions, zooming in and out is not currently possible because the aperture can not be opened enough to light you take a picture without being blurry. The auto focus would be taking priority in stopping you from taking a picture.
Just a hunch.
Jul 20, 2008 | Sony Cameras
Difference between Auto Picture/Program Mode
Auto Picture-selects on of the picture mode such as landscape(mountain), macro(flower), sport/action(running man) mode, etc. P-sets shutter and aperture. You set everything else. happy face- sets shutter, aperture and everything else.
Sep 08, 2005 | Pentax *ist DS Digital Camera
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Difference between the D-460 and the D-450 Zoom digital camera
The D-490 Zoom shares the following features with the D-460 Zoom: •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •3x image magnification inspection mode •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self-timer •8MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-490 Zoom has the following functions and features: •2.1 megapixel resolution (1600 x 1200) •Sequence mode - up to 5 shots in HQ and up to 45 shots in SQ mode (1.3fps) •Motion picture mode - up to 60 seconds of QuickTime movie (.mov) format (w/o audio)
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Difference between the D-460 Zoom and the D-490 Zoom digital camera
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
120 people viewed this question
Top Panasonic Cameras Experts
STEVE SPAM REMOVER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
