Question about Tomtom One XL GPS Receiver
How do I update my device
My device needs to be updated
Ankit Agarwalla
    New Friend:
  • 3 Answers
Step 1 Connect the TomTom One XL to your PC using the receiver's USB Cable.
Step 2 Launch the TomTom Home software on your PC and log in to your account.
Step 3 Click "Tools" and select "Use Latest Map Guarantee" to begin the update.
Posted on Feb 19, 2016
Windows has stopped this device because it has reported problems. (Code 43)
A Code 43 error message indicates that the Microsoft Windows operating system has stopped a hardware device because it has failed. Although the problem might be a technical fault with the hardware device, troubleshooting the device's software drivers will often fix the problem. Troubleshoot a Code 43 error from the Windows Device Manager or by downloading updated device drivers.
Windows displays the Code 43 error message and prevents the hardware device from activating when one of the drivers controlling the hardware notifies the operating system that the device has failed. If your computer displays a Code 43 error, Microsoft advises you to first check the hardware device's documentation for advice on common problems and how to troubleshoot the device. This may include reinstalling the device. If the hardware seems to be working properly, try troubleshooting the device drivers. b> Device Troubleshooting Wizard b> Windows includes an integrated troubleshooting wizard for hardware devices. To access this feature, open the "Devices and Printers" folder from the Start menu. Right-click the device and then select "Troubleshoot" from the context menu. Windows automatically checks the device and attempts to detect and automatically fix problems. You might need to click the "Yes" button during the procedure to download software or driver updates. Update Drivers With Windows Update b> Updating hardware device drivers with the Windows Update tool can also fix hardware problems. Click "Check for Updates" in the left pane of the Windows Update tool that you can access from the computer's Control Panel. Windows Update displays the number of important, recommended and optional updates in the main pane. On the "Select Updates You Want to Install" page, click and enable the check box for the hard drivers that you want to install. Click "OK" to automatically download and install the items. b> Update Drivers With the Device Manager b> If you don't want to rely on Windows Update, you can also manually update drivers for the problematic hardware with the "Device Manager" tool that you can access from the Control Panel. Double-click on the faulty hardware, which the Device Manger might label with yellow-black exclamation mark icon. Click the "Driver" tab in the dialog window, and then click the "Update Driver" button. Windows checks for driver updates and, if found, automatically installs the new drivers. You might need to restart your computer at the end of this process. b> Service and Repair b> If you can't resolve the problem by following the recommendations in the manufacturer's help documentation, or by troubleshooting the device and updating drivers with Windows, you might need to contact the manufacturer to arrange for the device to be serviced or repaired. You should find service and repair information or contact details in the device's user manual or in the support section of the manufacturer's website. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution note: it will find all of your outdated drivers This is a free driver solutions.
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Dec 10, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
Jun 16, 2011 | Nokia N73 Cellular Phone
Frozen, blink 0 for deepth, and sofrwer upgade
Updating Handheld/Portable Devices If your device has removable batteries, such as 2 AA batteries or a lithium-ion battery pack, then it is a handheld/portable device. You can update your device software for free using WebUpdater and a compatible cable.
Updating Fixed Mount Devices If your device needs to be hard-wired to your boat's power supply, then it is a fixed mount device. You can update the software by inserting a data card containing a software update bundle into your device.
You have 2 options for obtaining the update bundle:
  1. Do it yourself: Download the free software update bundle to a data card (SD™ card and card reader or Garmin Data Card and Garmin Data Card reader required).
  2. Purchase the software update bundle on a preloaded data card.
Get the software and instructions here:
http://www8.garmin.com/support/software/marine.html
Jan 15, 2011 | Garmin Fishfinder 400c With Dual Beam...
How to upgrade my nokia 3230 firmware?
  1. Tip: It is always recommended to backup your data before updating your software. However, updating using your device does not necessitate a full backup.
    Step 1 Step 2 Step 3
    Key *#0000# into your phone's home screen or go to Device manager(consult your user guide if necessary) Select Options > Check for updates. Follow the on-screen prompts until your update is complete!
    The above instructions may not apply to all devices. For detailed instructions on updating your particular device, please select your model on the Device software update page.
    Back to top
  2. update_with_pc_1.jpg 1) Download and install Nokia Software Updater (this need only be done once). update_with_pc_2.jpg 2) Connect your phone to your PC with a suitable USB cable and open Nokia Software Updater. update_with_pc_3.jpg 3) Follow the on-screen prompts until your update is complete!
Jan 15, 2011 | Nokia 3230
I WANT TO INSTALL RM 32.001
sir just download the nokia software updater from the below given link
link
se your phone's SW update feature to get software updates over the air or via Wi-Fi - no PC needed.
Please note that not all device updates are available over-the-air. To see what the latest version for your phone, see the "Can I Update" section of Device Software Updates.
To learn more about SW update and its benefits, see the "How to" section of Device Software Updates.
Set your device to alert you when new software updates are available.
  1. Select Applications > SW Updates.
  2. Choose the software you'd like to update.
  3. Follow the instructions.
You may also be able to update individual applications even if there is no software update available for your device.
Jan 05, 2011 | Nokia N79 Cellular Phone
I need a software update for my phone moto rokr e6
Please download this file and install it to update your moto
Please click here
step1.jpg You need the following USB cable type to perform the Software Update : Mini USB Data Cable. If you don't have a USB cable, you can purchase it here. Motorola Software Update provides the latest approved software for devices that are in warranty. Please note that your device's warranty status will be automatically verified prior to proceeding with an update. Please also note that your device may already contain the latest software available for your product. Motorola Software Update will notify you if an update is available once you download the update application and connect your device.
var strMonthSession='' var strYearSession='' if (strMonthSession=='1') { document.write("Jan"); } else { document.write("Jan"); } if (strMonthSession=='2') { document.write("Feb"); } else { document.write("Feb"); } if (strMonthSession=='3') { document.write("Mar"); } else { document.write("Mar"); } if (strMonthSession=='4') { document.write("Apr"); } else { document.write("Apr"); } if (strMonthSession=='5') { document.write("May"); } else { document.write("May"); } if (strMonthSession=='6') { document.write("Jun"); } else { document.write("Jun"); } if (strMonthSession=='7') { document.write("Jul"); } else { document.write("Jul"); } if (strMonthSession=='8') { document.write("Aug"); } else { document.write("Aug"); } if (strMonthSession=='9') { document.write("Sep"); } else { document.write("Sep"); } if (strMonthSession=='10') { document.write("Oct"); } else { document.write("Oct"); } if (strMonthSession=='11') { document.write("Nov"); } else { document.write("Nov"); } if (strMonthSession=='12') { document.write("Dec"); } else { document.write("Dec"); } for (i=2004;i"+i+""); } else { document.write(""+i+""); } } warranty-check.gif spacer.gif --> During the software update, all third-party media, including but not limited to, music, pictures, ringtones, and screensavers, will be deleted. You will need to reload all third-party media after the software update. Third party applications and some custom settings CANNOT be automatically restored after the device has been updated. Please note that during the update, you will have the opportunity to save your personal data.
Thanx and i hope this helps
Oct 09, 2010 | Motorola Mobility ROKR E6 Smartphone
I installed xp on my hp a6683w and it does not have the driver for the network card. i cannot get it from hp because it was a vista machine. where can i get the driver
Most HP and Compaq computers come with full versions of Microsoft Windows preinstalled. Microsoft has an extensive library of software, drivers, and updates available for free download. HP and many of its partners work with Microsoft to provide drivers through Windows Update. Use the following steps to download drivers, software, and updates by using Windows Update:
  1. Connect to the Internet and see http://www.update.microsoft.com (in English).
  2. Follow the directions in the Windows Update page to set up Windows Update and install the software updates.
  3. Be aware of the following tips when using Windows Updates:
    • Install all critical updates first to help keep your Internet connection secure.
    • If you are looking for drivers, they can be found as optional updates from the list of available updates.
    • Due to file sizes, number of updates, and download time, use Windows Update when the computer is not being used for other activities.
For more detailed information about using Windows Update to install drivers and get updates for Windows software, see the HP Support document Updating Drivers and Software with Windows Update .
NOTE: Another great way to quickly get updated drivers from Microsoft is to open Device Manager, right-click the name of the device, and select Update Driver Software . Updating a driver from Device Manager c01162470.gif
Sep 25, 2009 | Computers & Internet
How can i update my moto e6 phone
Please click here
step1.jpg You need the following USB cable type to perform the Software Update : Mini USB Data Cable. If you don't have a USB cable, you can purchase it here. spacer.gif step2.jpg Motorola Software Update provides the latest approved software for devices that are in warranty. Please note that your device’s warranty status will be automatically verified prior to proceeding with an update. Please also note that your device may already contain the latest software available for your product. Motorola Software Update will notify you if an update is available once you download the update application and connect your device.
step3.jpg During the software update, all third-party media, including but not limited to, music, pictures, ringtones, and screensavers, will be deleted. You will need to reload all third-party media after the software update. Third party applications and some custom settings CANNOT be automatically restored after the device has been updated. Please note that during the update, you will have the opportunity to save your personal data.
Please donot forget to rate this solution
Jul 17, 2009 | Motorola Mobility MOTOROKR E6
Missing dvd driver
after you update the BIOS
update the DVD firmare
update the driver for flash reader...i believed you have Texas instrument reader and they have update driver for xp and vista
after you update the driver ..check also the hardware update for microsoft...do custom update when you access windows update
Jan 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Tomtom One XL GPS Receiver Logo
52 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
