Car Audio & Video Logo
A
Anonymous Posted on Feb 19, 2016
What's this it's at the back of power acoustik subwoofer 500w low Q Driver also it has filter 50 80 120 225 on one side and the on the other it has gain min max
Steve Sweetleaf
Level 3:
  • Master 1,212 Answers
  • Posted on Mar 03, 2016
Steve Sweetleaf
Master
Level 3:
Answers
1212
Questions
5
Helped
433545
Points
3475
Set gain low. the other is your filtering frequency as at what hertz you want to listen at switch threw them for your best sound.
1 Related Answer
richie46
  • 12962 Answers
  • Posted on Feb 18, 2016
SOURCE: I got power acoustik subwoofer low Q Driver 500w it's for car but have it connected to tv, the speaker wrks but how do I know if the that's on the back of round housing.
Question makes no sense.
Need to if I can connect a power acoustik 500w subwoofer to my hometheater system, and if so need wiring diagram
you can do it but that bass cannon will not power the sub well at all. They put out maybe 40 watts RMS. best to find a cheep receiver and do it that way a lot less hassle. better sound. If you dont understand give me a shout.
1helpful
What is this ? On the back of Power Acoustik 500w subwoofer
Sub-woofers work on a low hertz as per audio. You have a built-in amp that has a crossover that separates frequencies under 100 Hz. Typical Hertz range is between 20-60. Since you have a built-in amp the black rectangle is a heat sink which helps to dissipate heat away from the internal components and also seconds as a cover to keep debris and other foreign objects from getting to the amp and burning it out.
Hope this helps.
Can i hook up My 500w Power Acoustik subwoofer to my entertainment center
yes, but you will need a significant 12 volt power inverter to support 500 watts
I have a power acoustik subwoofer, how do I know if the amp at the back of the round tube works the12" speaker wrks 500w voice coil 2, 89db low Q Driver. know it's for car's but I use it with tv spk
the shown photo is a bit confusing too me , clearly this is an automotive speaker , but in the photo there is clearly a home power cord shown , is this power cord connected anywhere on this speaker ? as if it is , id be afraid that amp has received home power and not car power , as the two are not the same and have tremendous differences and would be quite damaging to this amp possibly unrepairable damage
1helpful
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
