Question about General Electric Washing Machines
GE - GTUP270gm1ww, washer throws a lidlock failure every third wash. replaced control board and lid lock. still does it.. help
GE WASHER / DRYER GTUP270GM1WW - throws a lid lock code every third wash. Replaced control board and lidlock, but still does the same. Two service calls and still have the same problem. Help!
Posted by Jim Griffin on
1 Related Answer
russ_hill007
Russ Hill
  • 4057 Answers
SOURCE: gtup270gm1ww fills,wont run light flashing?
have you checked the motor there is a n over load resistor in the motor for when it over heats then the motor will not run if it has blown you will need a new motor as it cannot be changed, check it with a meter there should be resistance in the motor if its open then it has blown.
Posted on Jan 25, 2015
2answers
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
2helpful
Lid lock broke
My lidlock is broke, is there any way to bypass that so washer will work?
The locking lid mechanism is malfunctioning. It clicks three or four times then the letters FL are displayed.
this is what I suggest to you.
F=means Failure
"L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
good luck to you.
I have a Oasis, model 110 270 826 02, serial #CT3270410, that I just had the touch pad ERC control part (8564392) replaced last week. Today when I went to use it, the DU comes up on the control panel...
The DU error code indicates that the control detects a problem with the washer door (lid) unlocking. In this situation, the failure is normally caused by a failed door lock assembly. I provided technical information on this failure in the first image below. You can use this information if necessary to verify a failed lid lock assembly. The control is apparently sending the voltage to the lid lock mechanism to unlock the door but is not sensing that the lid is unlocked. There is a chance that you have a wiring failure or a bad control board so it is best to thoroughly diagnose the failure if possible before replacing components. Be sure that you unplug the washer before accessing internal components. If you determine that you have a failed lid lock assembly, you can use the procedure shown in the second image below to replace this component.
2helpful
LE message, will not lock the door - Daewoo front load
Hello there:
This is a fairly common problem with these newer machines Here are the 2 most common fault codes on these machines I have listed below this post.
If the machine is still under warranty i would suggest using it normally they will repair this for free
and some of these have a recall on these machines
so i would contact the appliance center where you got this from and see if you can get it repaired ok?
"LE " persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board. 1E persists in washer display Lid lock failure Replace lid lock switch or control board.
MAGTAG STACK WASHER
The 1E error codes relates to a lid lock failure. You should replace the lid lock switch. Good luck!
Washing Machines Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
