Question about Garden
I can start my Stihl HS 82 Road hedge trimmers but the blades will not move. Is there a lock on it or what's wrong
Posted by Gary Mayhill on
Stihl hs86 set blade gap
You shouldn't have to set a gap.. the gap between the blades is 'pre-determined' by a spacer between the blades that each 'blade bolt' passes through. You should be able to tighten up the blade bolts and the blades should still move. If they dont, then the spacers are worn and need to be replaced.
Apr 02, 2014 | Stihl Hedge Trimmer Pruner Cutter Blade...
Stihl hs45 will not start but it will run after i use auto start
Check fuel lines, filter and carb... Sounds like a poor fueling issue. clean and replace carb diaphrams. Check gaskets between cylinder and carb.
Feb 23, 2014 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Sthil hs 81 t blades don't move
I have The same problem,after opening the gearbox cover found that one of the connecting rods bearing cage broken and needle bearings everywhere and both thrust plates damage . In order to get it fix will be as well buy a new trimmer.
Nov 16, 2013 | Stihl Garden
MY sTIHL hs 81T HEDGE TRIMMER IS DIFFICULT TO START, AND THEN CUTS OUT WHEN THROTTLE IS OPENED AFTER A WHILE
Sounds like a fueling problem, Could either be over fueling or under fueling. Is fuel making it into the cylinder.? Is the plug excessively wet.?
Aug 04, 2012 | Stihl Hs 81 T Hedge Trimmer Cylinder Hs81t
Stihl hs 45 Trimmer
remove clutch from stihl hs 45 engine
Apr 07, 2009 | Garden
Reassembly of trimmer blades to stihl HS 80 hedge trimmer
My request from you was for a schematic of assembly for my stihl HS 80 hedge trimmer. You did not send but rather gave general advice. I solved the problem by calling a small engine repair shop and asked them to fax me a photo copy. You all were of no help and appear more to want money via bait and swithch. THUMBS DOWN to you!
Mar 19, 2009 | Garden
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
john h
ray gallant
