Replaced the light switch. Fuses OK
Park lamp fuse 20amp located in the under hood fuse box .DRL control module
Daytime Running Lamps (DRL) Control Module
Right of the steering column, behind the IP
Park, Sidemarker, Tail and License Lamps
Voltage is applied continuously to the PARK fuse to the headlamp and the instrument panel (IP) lamp dimmer switch through CKT 1340.
When the headlamp and the (IP) lamp dimmer switch is in the PARK or HEAD position, voltage is applied to CKT 9 thus activating the following lamps:
• The park lamps
• The side marker lamps
• The tail lamps
• The license lamps
The park/turn lamps are the only lamps that do not activate yet receive a current from CKT 9. The park/turn lamps do not activate because the voltage drop across the front side marker lamps is much higher than that across the turn lamp filaments
Step
Action
Normal Result(s)
Abnormal Result(s)*
Turn the headlamp/instrument panel (IP) lamp dimmer switch to the PARK position.
The following lamps light:
• The license plate lamps
• The taillight lamps
• The front side marker lamps (Domestic)
• The front parking lamps (Domestic)
The headlamp position lamps (Export)
Refer to Park Lamps Inoperative
Step
Action
Value(s)
Yes
No
Inspect the PARK LP fuse.
Is the fuse open?
YES - Go to Step 2
NO - Go to Step 3
Repair a short to ground in CKT 1340.
Is the repair complete?
Go to Exterior Lights System Check
Use a test light in order to backprobe the headlamp/IP lamp dimmer switch harness connector between terminal R and ground.
Did the test lamp light?
Go to Step 7
Go to Step 4
Use a test light in order to backprobe the headlamp/IP lamp dimmer switch harness connector between terminal O and ground.
Go to Step 5
Go to Step 6
5
Replace the headlamp/IP lamp dimmer switch. Refer to Headlamp Switch Replacement .
6
Repair the following conditions in CKT 1340 between the PARK LP fuse and the headlamp and the IP lamp dimmer switch harness connector terminal O:
• A faulty connection
• An open circuit
7
Repair the following conditions in CKT 9 between the headlamp and the IP lamp dimmer switch harness connector terminal R and S204:
• An open circuit
SOURCE: 1998 wrangler turn signal/brake light short
your socket may not be grounded properly, I have seen this before, and the simplest way to fix is change the socket with a new one.Not another used one it may also be bad.
SOURCE: 1996 carpice classic park lights fail
their is another fuse box in the engine compartment check that as well
SOURCE: Taillights are not working
check for voltage in the socket. positive is the center connection. if you have no voltage there, then you may be right. Make sure that you check the wires.
SOURCE: No Brake Lights, unable to switch from park to drive
It is not the multifunction switch. The power feed goes thru the brake switch before the multi function. You have no power the the brake switch because your shift interlock is not allowing you to shift it. I'll look up the wiring diagram and repost with a solution.
