Tutorial written on November 19, 2015 This tutorial will explain in detail how to reset Windows Tablet IRULU Walknbook. IRULU Walknbook If you want to return to the IRULU Walknbook to its factory settings, you only need to follow a set of instructions that give you here. We will explain two methods to achieve make the Windows reset. As a first step and before the hard reset, you must have charged the battery in your tablet as a whole, this for a blackout occurs during the process that damages the Windows operating system that has Reset Windows Tablet IRULU Walknbook by menu When you access the menu of your Tablet IRULU Walknbook follow these steps to reset a Windows fast and efficient. Swipe the menu and touch Settings Now it Change PC settings Select Update and recovery, then Recovery Touch Remove everything and reinstall Windows, select Next Choose the option to delete the unit completely Tap Reset You will see your Tablet IRULU Walknbook restart and start the process (this may take several minutes) When finished you will have been completed to make reset Windows Tablet IRULU Walknbook Reset Windows Tablet IRULU Walknbook using your keyboard This Windows reset is also very effective, just about to connect your keyboard to your IRULU Walknbook to carry out the process. Tap the On / Off icon on the login screen. Press and hold the Shift key while pressing touch Restart A menu will appear on the screen, select: Troubleshooting Tap Reset your PC Your Tablet IRULU Walknbook reboot and see the logo screen, wait a moment On the Reset your PC screen, tap Next Select the option: Delete the unit completely Touch Reset and wait a few minutes That's all, if you've done it correctly, you've managed to reset Windows Tablet IRULU Walknbook.
http://resetwindows.net/tag/irulu-walknbook/
Translated by google translate
