Tour Trek 4-Sided Deluxe Golf Cart Cover FE Logo
Posted on Feb 17, 2016
I need to get few more metal hocks for my golf cart cover.
1helpful
Ezgo txt golf cart hesitates and looses power, yet shows full battery charge.
loose power connection or bad ground somewhere. get a little metal wire brush (or several of them), disconnect battery, and disconnect ground and power wires (keeping track of them), and start brushing them, then re-attach and test
Is it possible to speed up an electric golf cart?
Most electric golf carts run on a max speed of 12MPH. It all depends on the voltage. The higher the voltage, the faster the speed. Most electric carts out there run on either a 36 or 48 volt operating system and can only last about 20-25 miles per each charge.
There are some new carts coming to market that are able to travel faster and possibly on less energy and can go up to 19 MPH. Many of the latest models are operated by computers and have quite a few high quality and unique components compared to older trolleys and carts. If you want or need something faster, they are worth look into.
Aug 17, 2018 • Golf
2answers
Need wiring diagram for a 2010 Gas Yamaha g29 golf cart
Try a electronic flasher. Wire power to flasher from light switch. Then wire flasher to lights.
Apr 08, 2017 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
1helpful
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
We have a Yamaha 2009 golf cart that bounces. We have a speed chip put in the cart and it started bounce. We've checked and replaced the tires. The mechanic at the golf cart dealer can't fi
Replace the chip with the original one and see if the problem is still there, If it isn't then the problem is with the chip, perhaps the golf cart is going faster now and the suspension cannot dampen as efficiently?
Top Tour Trek Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Tour Trek Golf Expert? Answer questions, earn points and help others
