Ah yes, the ultimate battle. Unfotunately if you want to get the bottom drawer unstuck yourself you're going to have to fight with it. The best way to get this drawer out other than asking your kids to try, is quick jerking motions back and forth holding both sides. Make sure you keep the stove secure while you battle this. If you can get it open some of the way, use a stick or something to try to jumble up all the pots and pans you have down there keeping it from opening. If you have nothing in the drawer, then maybe use a broom handle to pry it out, or have someone tilt the stove back to see what's restricting it. If worst comes to down to it, you can call a repair guy and watch him struggle to get it open.
The controller has a problem. The reason drawer will not open is the lid seal motors are stuck and will not let the drawer open. Turn mains power off and pull the drawer. Will need to replace the controller on this drawer. I am assuming the other drawer is working fine.
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
