I keep getting the same answer that vmail may be full! I keep stating that voicemail HAS BEEN retrieved. I cannot get rid of the fast flashing red light. I have gone to each phone and intercomed from each phone too.
SOURCE: 2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
SOURCE: nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
SOURCE: AVAYA MERLIN ETR-18D TELEPHONE
The following is from here.
IF you have a Lenend or Magix system. IF SO, you will have a VERY LARGE display phone, ususally at the receptionist station. It will be either a MLX20L or a 4424LD+. If so....
Changing the time on a Avaya Merlin Magix system is accomplished
from the system programming console. The date is change separately from
the time.
Changing the date:
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Date
6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Changing the time:
1. Press Menu
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
SOURCE: When I try to get my voicemail by pressing VMAIL
The only way to fix it without your vendor getting envolved is to try to reboot your voicemail server/phone switch(depending on the model of your system it can be inside of your switch or separate computer).
Your voicemail is down right now
I do not deal with your system but I see similar problems in other phone systems. This MAY be what is happening...
The message light can be a voice mail indicator OR someone on another phone in the building can leave you an intercom message (no voice system used or required). In those cases you need to return the message by pressing the MSG button, this should make the phone ring that left you the message in the first place. That phone needs to be answered to return the message and cause your light to stop flashing.
