Question about One For All URC-4750 Remote Control
Zenith code for urc 4750800 needed
One for all remote
Posted by MICHAEL BRENNEN on
Jeff Remotes
    Habit-Forming:
    Scholar:
  • 92 Answers
Zenith TV 0017, 0463, 0016, 0092
Zenith VCR 0039, 0000, 0209, 0033, 0479
Zenith DVD Player 0503, 0591
Zenith TV/VCR Combos 0000
Posted on Feb 29, 2016
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Posted on Dec 12, 2007
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: i need a code for my remote modele urc-6800b00 for my tv zenith
Magnavox 0054, 0706, 0030, 1454, 1254
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Anonymous
SOURCE: access codes for One for all URC4640
not listed at all, try searching for your
code. For example, to search for a code
for your TV:
blinks twice, then release SET.
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
the TV turns off.
control will send IR codes from its library
most popular code first.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
devices, repeat steps 1 through 5, but
for the device you are searching for.
I found this off a urc-4605 manual online but I think it works for all models worked for my urc4640b00
Posted on May 20, 2009
Anonymous
SOURCE: One For All URC-4330 Remote Control and toshiba tv codes
i need the code for a samsung tv
Posted on Jan 21, 2010
Anonymous
  • 1274 Answers
SOURCE: universal remote codes (one for all urc-5705)
The codes for the TV are....0017,0463,0178,0092...the code for combo is 1762....hope this was helpful...
Posted on May 17, 2010
Tip
Radio Shack Remote Control Remote Codes 150-2000 thru 630-5311
RadioShack Itza-2 Universal Remote Control (Purple) <a href="http://support.radioshack.com/support_video/60765.htm">150-2000</a> <br /> RCA RCU410 Remote Control <a href="http://support.radioshack.com/support_video/66870.htm">150-2101</a> <br /> RadioShack 4-in-One Light-Up Remote <a href="http://support.radioshack.com/support_video/64489.htm">150-2102</a> <br /> RadioShack 5-In-One Learning Light-Up Remote <a href="http://support.radioshack.com/support_video/64491.htm">150-2103</a> <br /> RadioShack 6-in-1 Home Theater Remote Control <a href="http://support.radioshack.com/support_video/64493.htm">150-2104</a> <br /> RCA RCU600RS 6-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/66945.htm">150-2105</a> <br /> RadioShack 8 In 1 Touch Screen Remote Control <a href="http://support.radioshack.com/support_video/65894.htm">150-2107</a> <br /> RCA RCU300 Remote Control <a href="http://support.radioshack.com/support_video/67858.htm">150-2109</a> <br /> RCA RCU500 Universal Remote Control <a href="http://support.radioshack.com/support_video/67860.htm">150-2111</a> <br /> RadioShack 3-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/69065.htm">150-2113</a> <br /> RadioShack 4-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/69067.htm">150-2114</a> <br /> RadioShack 4-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/70735.htm">150-2114A</a> <br /> RadioShack 5-In-1 Remote Control <a href="http://support.radioshack.com/support_video/69108.htm">150-2115</a> <br /> RadioShack 8 In 1 Remote Control <a href="http://support.radioshack.com/support_video/69110.htm">150-2116</a> <br /> RadioShack 8-In-1 RF Learning Remote Control <a href="http://support.radioshack.com/support_video/69112.htm">150-2117</a> <br /> RadioShack 4-In-1 Remote Control <a href="http://support.radioshack.com/support_video/72447.htm">150-2118</a> <br /> Philips Magnavox SpongeBob SquarePants 3-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/72638.htm">150-2122</a> <br /> RadioShack 3-In-1 Football Remote <a href="http://support.radioshack.com/support_video/68789.htm">150-2125</a> <br /> RadioShack 4-In-1 Flag Remote Control <a href="http://support.radioshack.com/support_video/69864.htm">150-2126</a> <br /> RadioShack 3-in1 Golf Bag Remote <a href="http://support.radioshack.com/support_video/69204.htm">150-2127</a> <br /> Universal Big-Button Remote For Special Needs <a href="http://support.radioshack.com/support_video/69934.htm">150-2129</a> <br /> Guide Remote Programmable 4-In-1 Remote Control <a href="http://support.radioshack.com/support_video/72688.htm">150-2130</a> <br /> RCA 4-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/73238.htm">150-2131</a> <br /> RCA RCU600BL 6-In-1 Remote Control <a href="http://support.radioshack.com/support_video/73922.htm">150-2132</a> <br /> RadioShack 6-In-1 Touchscreen Remote Powered by Kameleon <a href="http://support.radioshack.com/support_video/69319.htm">150-2133</a> <br /> RadioShack 5-In-1 Universal Remote <a href="http://support.radioshack.com/support_video/70587.htm">150-2135</a> <br /> RadioShack 4-In-1 Remote Powered by Kameleon w/Light-Up Keys <a href="http://support.radioshack.com/support_video/72091.htm">150-2136</a> <br /> RadioShack 8-In1 Touchscreen Remote Powered by Kameleon <a href="http://support.radioshack.com/support_video/73014.htm">150-2138</a> <br /> Sony RM-V202 4-In-1 Remote Control <a href="http://support.radioshack.com/support_video/73919.htm">150-2139</a> <br /> RadioShack 4-In-1 Family Favorites Universal Remote <a href="http://support.radioshack.com/support_video/72875.htm">150-2142</a> <br /> RCA RCU450 4-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/72939.htm">150-2145</a> <br /> RadioShack Remote Control Keychain <a href="http://support.radioshack.com/support_video/68965.htm">630-1166</a> <br /> Universal Electronics Remote Control Watch <a href="http://support.radioshack.com/support_video/69954.htm">630-5311</a>
on Jun 11, 2011 | Televison & Video
Tip
Radio Shack Remote Control Code Instructions 150-1901A thru 150-1999
Realistic Universal Remote Control <a href="http://support.radioshack.com/support_video/26219.htm">150-1901A</a> <br /> RadioShack 8-In-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/26221.htm">150-1903</a> <br /> Realistic Four-in-One Remote Control <a href="http://support.radioshack.com/support_video/26223.htm">150-1904</a> <br /> RadioShack 4-in-1 Remote Control <a href="http://support.radioshack.com/support_video/9536.htm">150-1904B</a> <br /> RadioShack 6-in-1 Remote Control <a href="http://support.radioshack.com/support_video/6663.htm">150-1905</a> <br /> RadioShack 3-in-1 Remote Control <a href="http://support.radioshack.com/support_video/9537.htm">150-1906</a> <br /> RadioShack Easy VCR Programmer Remote Control <a href="http://support.radioshack.com/support_video/7973.htm">150-1907</a> <br /> RadioShack 5-in-1 Remote Control <a href="http://support.radioshack.com/support_video/6570.htm">150-1908</a> <br /> RadioShack 4-in-1 Remote Control <a href="http://support.radioshack.com/support_video/6725.htm">150-1909</a> <br /> RadioShack 3-in-1 Remote Control <a href="http://support.radioshack.com/support_video/9538.htm">150-1910</a> <br /> RadioShack Light-Up Remote Control <a href="http://support.radioshack.com/support_video/9539.htm">150-1911</a> <br /> RadioShack Itza Remote Control <a href="http://support.radioshack.com/support_video/9540.htm">150-1912</a> <br /> RadioShack Itza Remote Control <a href="http://support.radioshack.com/support_video/35323.htm">150-1913</a> <br /> RadioShack Itza Remote Control <a href="http://support.radioshack.com/support_video/35315.htm">150-1914</a> <br /> RadioShack Pocket Remote Control <a href="http://support.radioshack.com/support_video/16680.htm">150-1915</a> <br /> RadioShack Pocket Remote Control <a href="http://support.radioshack.com/support_video/47657.htm">150-1915B</a> <br /> RadioShack 3-in-1 Easy Remote Control <a href="http://support.radioshack.com/support_video/16726.htm">150-1916</a> <br /> RadioShack 3-in-1 Easy Remote Control <a href="http://support.radioshack.com/support_video/44686.htm">150-1916B</a> <br /> RadioShack Phone Up 4 Remote Control <a href="http://support.radioshack.com/support_video/34875.htm">150-1917</a> <br /> RadioShack 6-in-1 A/V Remote <a href="http://support.radioshack.com/support_video/36485.htm">150-1918</a> <br /> RadioShack 6-in-1 RF Remote Control System <a href="http://support.radioshack.com/support_video/18620.htm">150-1919</a> <br /> RadioShack Universal Remote Control <a href="http://support.radioshack.com/support_video/15740.htm">150-1921</a> <br /> RadioShack 6-in-1 Remote Control <a href="http://support.radioshack.com/support_video/42245.htm">150-1923</a> <br /> RadioShack 7-in-1 Remote Control with Lighted Keypad <a href="http://support.radioshack.com/support_video/42247.htm">150-1924</a> <br /> RadioShack 6-in-1 IR/RF Remote Control <a href="http://support.radioshack.com/support_video/45116.htm">150-1925</a> <br /> RadioShack 3-in-1 Simple Pocket Universal Remote Control <a href="http://support.radioshack.com/support_video/50835.htm">150-1926</a> <br /> RadioShack 3-in-One Pocket Remote Control <a href="http://support.radioshack.com/support_video/48421.htm">150-1930</a> <br /> RadioShack 3-in-One Easy Remote Control <a href="http://support.radioshack.com/support_video/48700.htm">150-1931</a> <br /> RadioShack 6-In-1 Remote Control <a href="http://support.radioshack.com/support_video/51276.htm">150-1934</a> <br /> RadioShack 7-in-1 Home Theater Remote Control <a href="http://support.radioshack.com/support_video/51278.htm">150-1935</a> <br /> RadioShack One For All - The Finder Remote Control <a href="http://support.radioshack.com/support_video/34166.htm">150-1940</a> <br /> RadioShack Wireless Infrared Remote Control Extender <a href="http://support.radioshack.com/support_video/7039.htm">150-1959</a> <br /> RadioShack 2-in-1 Universal Remote Control <a href="http://support.radioshack.com/support_video/61532.htm">150-1989</a> <br /> RadioShack 3-In-One Pocket Remote <a href="http://support.radioshack.com/support_video/52292.htm">150-1990</a> <br /> RadioShack 4-In-One Remote Control <a href="http://support.radioshack.com/support_video/52294.htm">150-1991</a> <br /> RadioShack 4-in-One Light-Up Remote Control <a href="http://support.radioshack.com/support_video/52296.htm">150-1992</a> <br /> RadioShack 4-in-One Smart Light-Up Remote Control <a href="http://support.radioshack.com/support_video/52298.htm">150-1993</a> <br /> RadioShack 6-In-1 Smart Audio/Video Remote Control <a href="http://support.radioshack.com/support_video/52962.htm">150-1994</a> <br /> RadioShack 7-in-One IR/RF Remote Control <a href="http://support.radioshack.com/support_video/52964.htm">150-1995</a> <br /> RadioShack VCR Programmer Remote <a href="http://support.radioshack.com/support_video/61534.htm">150-1996</a> <br /> RadioShack Itza-2 Universal Remote Control (Clear) <a href="http://support.radioshack.com/support_video/56310.htm">150-1998</a> <br /> RadioShack Itza-2 Universal Remote Control (Purple) <a href="http://support.radioshack.com/support_video/56312.htm">150-1999</a>
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
I have lost my remote
Original and replacement remotes: www.remotes.lt
Sep 07, 2009 | Televison & Video
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
One For All URC-4750 Remote Control Logo
Top One For All Televison & Video Experts
Nick Charalampakos
Level 1 Expert
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
