That forward-to-another-number would usually be a function of the telephone company or service provider -- BUT the Vtech DS6522 and a similar AT&T phone do include a Bluetooth connectivity with an associated cellphone wherein the cellphone is the "service provider" and the Vtech handsets are "extensions" from the cellphone, a complicated scenario. See your model's manual ( it is available at www.manualslib.com ) and/or perhaps talk to your phone company. Good luck!
SOURCE: Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
SOURCE: vtech dect 6.0 missed calls show on caller id. I want to remove
Hey geowinnick,
To remove "missed calls" on phone, press and hold "OFF" button on handset. This should remove "missed calls" message.
SOURCE: I LOST MY INSTRUCTION BOOK FOR VTECH 6.O DECT
Vtech DECT 6.0 Dual Handset Cordless 6041 Phone If you click on the above it will take you through to the manual, hope i`ve helped
SOURCE: phone screen just say connecting
If is says connecting then most probably its not getting a connection from the base. It could also be your telephone line. Check if the line is active.
Please rate if helpful.
Thanks
SOURCE: how do i enable call
Hello! You can turn on call forwarding by pressing 72# then wait until you hear the two tones and dial your number that you wish to send the calls to and then hang up the phone. The two tones signal that it has understood your command and is putting the line into forward mode.
To turn off cal fowarding, press 73# and wait again for the two tones and hang up.
