How to Replace the Door Seal on a Washing Machine - Bosch
One of the most common faults of a leaking washing machine is a faulty seal. Thankfully replacing such a component of your washing machine is not a difficult task.
In the above video, with the help of our experienced team, we explain how to replace the washing machine door seal, and below we've compiled a simple step-by-step guide which takes you through every point covered in our video.
Step 1: To remove the door seal on any make and model of washing machine, you'll need to remove the entire front panel, followed by the soap dispenser and fascia.
Removing the panel and fascia is easy to do, once you've undone the screws holding it in place, whilst the soap dispenser should just clip out of place.
Step 2: With these components removed, clip away the kick plate, put the drain hose to one side before removing the retaining clip which holds the door seal against the front of the machine. Once the clip has been removed just push the seal inside.
Step 3: Undo the four remaining screws holding the front of the machine on, before pulling the front of the machine and the door away from the machine.
Once the front of the machine is off, you should be able to see the spring retaining band going all the way around thedrum. This should be easy to pull off, enabling you to peal the whole old seal away; once you've removed the old seal this can be thrown away, although it is advisable to keep the retaining band, as this can be reused with the new seal.
Step 4: You'll now be ready to attach the new seal, when doing so make sure that the drain holes are positioned at six o'clock; once you've done this it is just a case of working the new seal onto the drum.
With the seal worked onto the drum, put the retaining spring into its little ridge, before giving the seal one final check.
Step 5: Reattach all the parts back to your washing machine, attaching the door seal to the front of the machine ensuring that it goes over the lip, before attaching the retaining band on the bottom and sides.
There you have it, a step-by-step guide to replacing the door seal on a washing machine, helping it to perform to its optimum level.
SAJID
How to Replace the Door Seal on Washing Machine Bosch
SOURCE: washing machine replacement door seal
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
SOURCE: BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
SOURCE: fixing new rubber door seal
have Maxx bosch machine trying to replace robber door seal. Can you advice how to do this as having difficulty with spring retainers
