Anti flood device is on
SOURCE: Reset anti flood device in dishwasher Beko DWD 4310 S
**** the water out of the pan below the dishwasher, there is a float in the pan if you have a leak and the pan fills with water
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
SOURCE: newish Zanussi ZDF 511 dishwasher fills the antiflood device
If you cannot find a leak then check that if you are using the 4 or 5 in one tablets that you are not using rinse aid seperately as this is also in the tablets and salt.Too much rinse aid can cause the dish washer to froth up and this can overflow down the underside of the door causing the problem you have.
Hope this helped.
