Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Why doesn't fan start?
Bearings ok. Capacitor seems to be ok. Can sometimes spin the fan by hand to get it to start but motor is noisy.
Posted by Jeff Lough on
Motor will not keep running after i help start it turning
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 25, 2009 | Whirlpool ACQ158XP Wall/Window Air...
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
The compressor on my air conditioner was still running, but the fan was not running causing the temperature to climb in the house. I re-started the main power and the fan worked with the compressor wants...
Aug 20, 2009 | Heating & Cooling
Two units, one works fine the other unit fan does not come on.
Aug 16, 2009 | Heating & Cooling
Motor and fan fails to come on
Aug 15, 2009 | Ruud Matching Split Air Conditioner
Fan does not operate in my 54501 Kenmore dehumidifier; therefore, unit gets very hot.
Aug 11, 2009 | Kenmore 54501 Dehumidifier
Fan on unit not running
Aug 09, 2009 | Heating & Cooling
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Jul 31, 2009 | Dehumidifiers
Fan not working
Jul 31, 2009 | Fedders A7DH65B2A Dehumidifier
Friedrich quietmaster fan does not come on and compressor sounds like it might be laboring when switch is turned to high,medium,low cool. The airconditioner does work if the money saver switch in on. Once...
Jul 29, 2009 | Friedrich QuietMaster SL36L30 Air...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
97 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
