SOURCE: Honda pantheon scooter 125cc low
working on a 2003 125 honda FES Pantheon was working fine until it left the petrol station and just stopped, it had been over filled so drained some fuel out and cleared crank breather but still wont go. Anyone know what is wrong please.
SOURCE: honda pantheon fes 125 cc
FI stands for Fuel Injection. The fuel system sensors have detected a problem. It could be anything > a dirty air filter restricting airflow, a plugged injector, an error in fuel mapping, any number of things. Serious problems can trigger the computer to prevent the engine from starting until the problem is fixed. You will need to take the bike to a dealer to have them plug in a code reader. The code reader will tell you exactly what problem has been detected. There is also a chance a sensor has gone bad and is giving a false signal. Keep that in mind. Now determine if you want to do the fix or have the dealer do it.
SOURCE: where is chassis number on Honda FES 125 Pantheon 125?
The usual place to find the chassis number is on the headstock. This is because the headstock can't be changed as a spare part. The headstock is the point where the forks rotate in the frame.
SOURCE: How do I change the rear wheel of a 125cc 2004 Honda pantheon
CENTRE STAND IT AND SEE IF THERE IS A BIG NUT ON THE HUB, MAY NEED TO REMOVE EXHAUST, BUT NOTHING HARD ABOUT IT
