Question about RTO 50cc Moped Scooter
Why doesn't tail/brake light work?
Replaced socket
Posted by Annette Penley on
Timllfixit
  • 2,210 Answers
Do you mean, you replaced the bulb? Have you checked the wiring and ground connection to the lamp?
Posted on Feb 16, 2016
Tail light not working brake works
Justo change the socket or put some grease for bulbs
Nov 25, 2017 | Cars & Trucks
Tail lights/turn signals and driver brake lights work, passenger-side brake light doesn't
Find a multimerter or an ohmmeter and someone to work it and test the socket to see if electricity is getting to the bulb. Someone will need to push on the brake pedal whilst someone else tests it.
Sometimes a wire can break, or sometimes a metal contact inside the socket can go bad, or can bend in such a manner that the bulb no longer contacts it. Also, sometimes new bulbs are defective.
Be blessed.
Nov 19, 2013 | 2001 Dodge Grand Caravan
Brake light and tail light not working on one side
The brake light and tail light are on two different circuits.
They can use the same bulb if it is a double filament.
You probably have something wrong with the light socket or the ground connection.
Feb 28, 2013 | 1996 Dodge Stratus
Tail lights work but right brake light doesn't
I had a similar issue with my lincoln, it turned out to be the wiring to the socket, was corroded and broken. Since you have done the other things this would be the next plausable place to look. hope this helps
Jun 12, 2012 | 2001 Isuzu Trooper
Driver side brake light is not working. Replaced bulb, but didn't need to it is the same bulb that works the tail lights, which still worked. Ugh, 2006 jeep liberty. Someone said it was a brake...
THAT RIGHT IF BRAKE SWITCH BAD NO BRAKE LIGHT WILL WORK.SPRAY ELECTRICAL CLEANER IN BULB SOCKET BULB SOCKET COULD HAVE OXIDATION AND CORROSSION CAUSING POOR CONTACT.
Sep 12, 2011 | 2006 Jeep Liberty
EF Civic Brake light turns off during braking w/lights on
The characteristic you described is almost always a ground connection that is not secure.
Check with an ohm meter the resistance between the ground at the light socket and the chassis of the car. Any resistance is an indication of a poor ground connection. Temporarily connect the return(ground) connection at the socket to the chassis using a jumper.
If all is correct with jumper in place determine poor connection location and repair.
Hope this helps?
May 24, 2017 | 1988 Honda Civic 2 Door
NO power to tail light sockets
There is a breaker in your circuit box it is silver mine did the same thing and i had a loose wire on my head light switch and my breaker was blown...
Sep 23, 2008 | 1988 Jeep Cherokee
No tail lights or brake lights
Check the relays associated with the tail lights, I believe that the tail light relay and the turn signal relay are two different entities. Hopefully that helps.
Jul 08, 2008 | 1999 Jeep Grand Cherokee
RTO 50cc Moped Scooter Logo
53 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
