My unit runs but no heat and then shuts down, i did the test and get error codes FDL AND R11. I Replaced the igniter since it was broken and in bad shape but that didnt get it to heat up again, continues to shut down and no heat. Please help
Hello Lidia, thank you for your inquiry!
Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
f the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
I added the instructions in the image below on how to remove and replace the door lock mechanism. NOTE: Disconnect the power cord from the power source before removing and replacing the door lock assembly.
