Without a remote control, you can't. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
The buttons are on the screen but hard to see. From LEFT to RIGHT ... VOLUME (-)/also ?? , VOLUME (plus?)/also ?? ; ??(DOWN) CHANNEL ?? (UP); MENU ; INPUT & ON/OFF button on far R
SOURCE: Sansui without remote
No. You will need the remote. Call the number on the set for an original. You could try your luck with a universal remote. Try a RCA brand. Good Luck!
SOURCE: switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
SOURCE: HOW TO REMOVE PANEL LOCK ON A SANSUI LCD TV WITHOUT REMOTE
That tv usually has the customer service number printed on a sticker somewhere on the tv. Give them a call. They will help you for free. I hope this helps you.
SOURCE: tuning without a remote
pls use panel menu key prees and select tuing menu and see display in ASM [auto serch memory] select ASM befor ch.no set is "0" and select ASM .
use panel ch+ ch- is up and down select key is v+ and menu key is menu next page
