Question about Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz
Where is hdmi port - Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz
Posted by ramona milford on
richie46
    Top Expert:
  • Samsung Master
  • 12,962 Answers
If a new set it is somewhere on the back. Check your manual for exact location.
Posted on Feb 15, 2016
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
Trying to connect hdmi cable to laptop to watch movies
Are you sure you have four hdmi ports? I have only one hdmi port and three usb ports. Be sure you are connected to the hdmi port and for some reason not a usb port.
Aug 17, 2012 | Sanyo DP46849 46 in. HDTV
Where is the HDMI port on a Sony Bravia KDF-46E3000
There are two HDMI (High Definition Multimedia Interface) ports on your Television.Please refer the diagram below to know about the HDMI ports of your Sony Bravia KDF-46E3000.In the diagram the labeled ports numbered 6 and 7 are the two HDMI ports on your television.You can connect your TV with other devices which supports HDMI with an HDMI cable to view High Defenition videos.
Hope you are satisfied with my solution.Thanks for choosing Fixya.Your valuable feedback would be appreciated.
Jul 23, 2011 | Sony Televison & Video
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
The hdmi port on my Panasonic CT-30WC14 only works when I push the cable into the port and hold it. It has a bad connection. I was going to take the back panel off and see if I could connect to the port...
Not the HDMI port,it the HDMI cable is dead.If u have dead HDMI port holding the HDMI cable wouldn't work,make no difference.Change the HDMI cable will solved ur problems.
Sep 06, 2010 | Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
I have a 37" Insignia L37Q tv with 4 HDMI inputs. Only HDMI 1 works properly. If I hook up an HDMI device to any of the other HDMI ports I get one of the following: 1. No signal 2. Not supported 3....
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 16, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Jan 27, 2009 | Televison & Video
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
60 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
