Question about Nerf Toys
How do I get my Nerf rival 1200 to fire automatically
Posted by Kris Pennington on
webslingers
  • 8 Answers
Https://m.youtube.com/watch?v=spaayNFppaQ
Posted on Feb 14, 2016
1 Related Answer
Anonymous
SOURCE: Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Posted on Feb 25, 2010
Nerf gun lazer tag
i have the same problem and i noticed that when i go outdoor, the trigger will work again. i think it is something about interference by some sort of radiofrequenceis.
Nov 08, 2013 | Toys
I have a nerf nite finder that when i **** it back it fires without warning do you have a soulution
That sounds like an internal mechanism issue, parts of the plastic on the inside could have worn down, causing the spring to slip and fire the bullet off.
May 04, 2011 | Nerf Nite Finder
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Jan 04, 2010 | Nerf Toys
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
There is a gray battery cover a little bit above the trigger. You will see a screw hole
Jan 02, 2010 | Nerf Secret Strike As 1
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Toys Logo
85 people viewed this question
Top Nerf Toys Experts
MODERATOR Canada
MODERATOR Canada
WORLD MODERATOR
Alyssa DeWolfe
Alyssa DeWolfe
Level 1 Expert
Are you a Nerf Toy Expert? Answer questions, earn points and help others
