The movie recording error message indicates that the Camcorder is not in a position to record videos. It may be due to shake, free space, corruption in the folder structure, bad sectors in the HDD.
Please follow the below steps and check the operation. Each step is a possible resolution, so please perform one by one and check the operation.
- Place the Camcorder in a steady surface and press the record button.
- Please press the reset button on the Camcorder and check if that helps.
Make sure that you have turned ON the Camcorder while pressing the reset button..
You can locate the reset button from the below figure.
- If the issue persists again, format the HDD of the Camcorder and check the operation.
To format the HDD of the Camcordeer, you can use the HDD FORMAT option under the HDD set
Note:Formatting the HDD will erase all previously recorded videos and images from the Camcorder.
I hope this will resolve the issue
