Question about Lexmark P3150 All-In-One InkJet Printer
Lexmark p3150 unit says door open when it is closed. how do i get inside to find why and repair it
Posted by vesteros on
  • Anonymous Dec 05, 2007
    After changing a ink cartridge top would not go down, so I pushed down hard. Some thing in the printer broke off and the top went down.When I tried to print a message came on the screen to say the top was not down
    any help on how to open up the printer and see what has snaped off would be grateful
    Bav Vit
  • jenvic Dec 11, 2007
    the print says the top is open when its down what can i do to make it print
    i think something broke off i guess that was what made contact with someting please help
Soulvisitor
  • Lexmark Master
  • 1,113 Answers
Google is your friend, here is the solution I found from the web.
I finally got brave and opened my unit up to find that there is a presure switch in the back right corner. The printer door presure switch is in the back right corner. If you lift up the printer door you will see a light gray angle piece that goes down into the printer from the scanner bed. That is where the presure switch is. Most likely the little black rocker arm (it's about one inch long) came lose fromthe switch. You need to reseat the arm.
You have to remove the scanner cover door.
Then lift the printer door up and to the front left the red support needs to be disconnected from the Scanner bed. This is done by squeezing the top of the support until it releases.
Then you need to release the scanner bed from the printer. With the printer door up, look to the back right you'll see a light gray stop sticking down into the printer bed. Gently push that to the right and the scanner bed will be released from the printer. (It will have a little hook on the end.)
Now you can get at the two screws in the back corners of the top of the printer. Remove them and the two frot corner screws.
There are little tabs holding the top of the printer inplace. You need to work the top out of the tabs. Watch out for the 3 ribbon cable in the back right.
Move the top up and out of the way and then you can see the presure switch on the board to the back right. There should be a rocker arm pointing straight up so the scanner bed will hit it.
I had the very same problem. It was very tricky getting the plastic lids and other plastic items apart and then back together successfully. Using a small, straight screwdriver edge was helpful as a prying tool to separate the lid fingers from the plastic base.
Also, having a second person to assist was critical in order to feed ribbon cables back through lid and holding the scanner assembly at the same time. A great deal of patience and trial-and-error attempts are required. Using a very intense light source and a large magnifying glass or viewer will also help.
The black rocker arm fits on top of a very, very small microswitch that is mounted on the vertical circuit board. Lining up the lid with the gray, beveled device that contacts the black rocker arm should show you how to align the rocker arm.
This design indicates just how sloppy design manufacturing has become over the years ... all in the name of low-cost. Good luck to the rest of you Lexmark printer owners!
Posted on Dec 28, 2007
paul proctor
  • 4,102 Answers
On the door can you see the button that presses down into the printer it should press down into a little hole in the case if you can see this put something thin down the hole to press the switch if this tells you the door is closed then you know that it is just the button at fault and not the switch itself if you put a bit of pressure on the lid does it then tell you the door is closed post back and i will try help you some more
Posted on Nov 17, 2007
Belt repair for lexmark p3150 print trio multi-function
If you need lexmark customer support number 1866-877-0191.We are always here with tech team for your help. For further Info Click On Me:https://goo.gl/hvj3MK
Mar 11, 2012 | Lexmark P3150 All-In-One InkJet Printer
Can i use print cartridge 70 or 12A1970 for printer lexmark P3150
#70 cartridge is not compatible with the Lexmark P3150 printer. Compatible cartridges for your printer available in the Lexmark website at http://bit.ly/9DTsPt. Thanks.
Oct 13, 2010 | Lexmark P3150 All-In-One InkJet Printer
How to install the ink caridges in the printer for black, color and photo ink cartridges?
Perhaps the Lexmark P3150 User's Guide will be able to help you. Click on the link to download: http://bit.ly/bk5IRX. Scroll to Maintenance, Page 38, for instructions on how to replace/install the cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thank you for choosing Lexmark.
Sep 21, 2010 | Lexmark P3150 All-In-One InkJet Printer
Lexmark P3150 was working fine.But paper got jammed. I pulled the paper out and color cartrdge went to left side like a bullet and blue light in On Off switch started flickering. When I start printer...
Maybe you somehow detached the encoder strip when removing the paper.
First, before you put your hands inside the printer, unplug the power chord from your printer. This is important.
Then open up the lid and locate the horizontal metal bar.  Right above this there should be a semi-transparent plastic strip attached in the right and left side of your printer. If you see this, try moving it with your finger. If its properly attached, it should bounce back to it's original position. If it's loose, try to attach it to the right/left side again. If you can't find it, it probably fell off and is jammed inside the printer somewhere.
If the encoder strip looks OK, your carrier might have jammed in the left side of your printer. Keep the power chord unplugged.
See if you can unjam the carrier by pulling it along the metal rod. If should be fairly easy to move back and forth, so you'll know if it's stuck. If you can't loosen it, your printer is probably damaged beyond repair. Check if you have warranty on it.
Mar 05, 2010 | Lexmark P3150 All-In-One InkJet Printer
I NEED p3150 ALL IN ONE DRIVERS LEXMARK
http://support.lexmark.com/index?page=content&actp=DD_LIST&productCode=LEXMARK_PHOTO_P3150&id=DR12178&os=WINDOWS_XP&oslocale=en_US&segment=DOWNLOAD&userlocale=EN_US&locale=en
Just go to Lexmark.com and search for p3150, and you'll end up at the page above..
Nov 04, 2009 | Lexmark P3150 All-In-One InkJet Printer
Lexmark P3150 says cover is open
May be the cartridge not fitted properly.
Also try to unplug the printer during PC on. and then replug it.
Try to power off printer, restart PC and disconnect USB, then connect after restart PC.
Let me know if you need further help.
Oct 04, 2008 | Lexmark P3150 All-In-One InkJet Printer
Will Lexmark P3150 work on Mac OS 10.3.9?
P3150 printer comes with installation CD for MAC OS
Jul 17, 2008 | Lexmark P3150 All-In-One InkJet Printer
Lexmark p3150
You can download the driver files from Lexmark website. http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Photo+P3150
Sep 17, 2007 | Lexmark P3150 All-In-One InkJet Printer
Lexmark P3150 All-In-One InkJet Printer Logo
214 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
