Question about HP Computers & Internet
Admin/ Power On prompt on HP stream. Cant remember passcode. Any help you can offer would be much appreciated.Thank you. Model # 11-r020nr S/N : 5CD5459O2B P/N: N5X87UAHABA
Posted by Caatherine Cole on
Larry Ng
  • HP Master
  • 6,445 Answers
That is hacking
google how to hack bios PW.
hp.com told you NO, so you come here. sure.
if tpm was enabled it is doomed by DESIGN.
Posted on Jan 14, 2022
2 Related Answers
Anonymous
  • 3940 Answers
SOURCE: i need help with my Hp mini laptop that has admin
see if this helps
http://www.fixya.com/support/r3743393-ve_lost_or_forgotten_windows_password
Posted on Jan 16, 2011
jay169
  • 23 Answers
SOURCE: bios password removal
Have you tried resetting bios to default? There should be a jumper on the motherboard that says CMOS default or BIOS default. It is usually 3 pins with a jumper across 2 of them. Changing the jumper to the other unused pin and center pin, labled default, should reset bios to default and remove the password.
Posted on Jan 17, 2014
I upgraded my HP Stream pro 11, and now my touch pad is unresponsive
upgrade what?
from what to what. w7 to 10? what?
seems w8.1 to w10? came with both new, {OPTIONAL
what stream there are 18 models of stream.
i cant guess them at all , must be said.
there are 4 , Pro 11's in fact.
ever heard of HP.com? the company
they made it and the support page is here.
for touch pad for sure, called input devices on the software page.
ill do wild guessing, lacking your service tag data.
example, w10 64bit now.
https://support.hp.com/us-en/product/HP-Stream-14-Pro-Notebook-PC/15932849/model/15932850
are you internet connected?
be so
then in device manager. (CP)
click on the mouse pad driver there and click update driver yet?
if that fails
you need to load HP drivers, to make it work.
or just run the HP support assistant.??
http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
I forgot my power on or admin password on my hp stream model 11-d010wm can you help me
we cant ever guess, what PW you are being asked.
1: BIOS password, cant get to windows login screen.
2: windows 10 login, local
3: windows 10 login, at microsoft.com cloud. store, etc.
what is it?
and each has a different cure. ill not do them all, and is here on this forum and on HP forum 100,000 times and for 2 and 3 is on the MS forum 1+ million times.
ill do the #3,
https://account.live.com/password/reset
How to disassemble hp 11-d008TU/d009TU W8.1 Netbook'
Hi George,
I see that you are looking for instructions on disassembling your Stream Notebook. What seems to be the problem with the Stream? Perhaps, I can help.
If you have purchased this within the last year then you are in warranty and I wouldn't recommend taking anything apart as that may void the warranty. I can try helping here or you can contact HP at www.hp.com/contacthp
If your still looking at taking it apart I have included a link below to the Maintenance and Service Guide for your model. The instructions start on page 28 of the guide.
Maintenance and Service Guide:
http://h10032.www1.hp.com/ctg/Manual/c04491261
Thank you,
BHK6
I work on behalf of HP.
3helpful
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
How to open laptop with admin passwords
Go to start search
type CMD
u will get cmd option
rt click on that and do run as admin
cmd window will open
on the command prompt type
Net user administrator /active:yes
we will get a conformation about the activation of admin account............
it works
thank you
Forgot admin password-need to re-install parental controls
If you are still able to use command prompt, try the following:
a) Start, Run, type "cmd", Enter
b) type "net user user_name new_password
- user_name : will represent your admin user account name
- new_password : will represent your new password for the account
c) press enter
d) Restart the computer and login using new password
Port forwarding trouble
enter admin for username and password
Windows Login Password - Cant Safe Mode or Log in as Admin
Hey Steve/Becky - I have one question for you before I fix your problem. When you booted in safe mode, did it give an option of several logons, i.e.- yours and an administrators?
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
