Question about Philips PM435S Remote Control
Philips PM435S 4-Device Remote Control
Where can I download a manual for this...I got it used and never had one.
Posted by cperki on
  • 25 more comments
  • Anonymous Nov 27, 2007
    codes for pm435s contoller
  • Anonymous Nov 28, 2007
    need code for phillips receiver
  • heatherjohn Dec 14, 2007
    Got a Philips PM435S remote and only a partial code list. Need current codes for a Direct TV sat receiver. Please help!!!
  • kdeltoro Dec 16, 2007
    Can you tell me how I set my VCR to be controlled by this remote control.
  • Anonymous Feb 15, 2008
    my remote is not linking up with my TV any more I have a Panasonic
  • Anonymous Feb 19, 2008
    need to reprogram my remote
  • Anonymous Feb 26, 2008
    i have universal remote control. i want use that for a vcr. how to set the code?
  • Anonymous Mar 09, 2008
    lost list of devices codes
  • Abe15 Mar 19, 2008
    the tv code list
  • Anonymous Apr 07, 2008
    Phillips pm435s
  • emilie2766 Apr 13, 2008
    lost my manual to my Pm-435s-4 remote. Where can I get codes?
  • Tifanie P Apr 13, 2008
    I need codes for my TV and can not find the manual for the Philips PM435S 4-Device Remote Control
  • Drh831 Apr 15, 2008
    I have the same remote Philips PM435S 4. It was working but batteries fell out and now I can't find the codes. I'm using it for a Toshiba Tv with built in DVD player. I've tried the pressing code search and the channel up button a million times. Can anyone help?
  • Anonymous Apr 15, 2008
    down load manual
  • Anonymous Apr 21, 2008
    need product codes
  • shorty lo Apr 22, 2008
    need code list
  • vang84 Apr 22, 2008
    lost the codes and i need the code to a Insignia DVD/VCR player.
  • Anonymous Apr 25, 2008
    I lost the code my tv is sony
  • fenton71 Apr 26, 2008
    i have lost the codes to the remote and it was working but one day stopped.. i cant find the codes anywhere.. i have a panasonic
  • kemr-1 May 05, 2008
    I need the codes for a Toshiba T.V. and a General Electric (GE) VCR please.
  • Ancients May 24, 2008
    i need the code to a ge tv and i dont have a code list
  • Anonymous May 26, 2008
    how to program the reote for a Sharp television?
  • Anonymous May 29, 2008
    How do I put the tv in auxillary mode with this remote? The remote controls the tv ok but when I wantded to watch a movie by connecting to the front vedio plug in I couldn't put the tv in auxillary.
  • kkaatt Jul 29, 2008
    can you tell me how to program my philips universal remote pm435s 4-device...code in battery casing is clo34..........my tv is a sanyo......thanks?8)
  • cschell5 Aug 29, 2008
    I need the code for the PM-4353 phillips universal remote can anyone help?
  • Anonymous Oct 01, 2008
    i have a philips PM435S universal remote and a memorex tv and cant find the codes for it the code inside the battery compartment is CL034
  • cadie254 Oct 06, 2008
    well i have a sony dvd/vcr combo and a phillips universal remote but I lost the code book in the battery there is a sticker that has on it clo34
Anonymous
Anonymous
Thanks so much this helped been trying to get my remote to work for 2 weeks and your comment was the only one that worked thanks so much really helped! :D
Posted on Feb 18, 2008
Anonymous
_____________________________________________
Direct Code Entry
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicalor turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL UP. If the device responds. no further programming is required.
Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific Brand within the Code Library for a particular manufacturer.
1. Tum on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator remains on, then release the CODE SEARCH button.
3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9) corresponding to desired Manufacturer (see table below). Note, pressing "0" performs a full library search same as Device Library Code Search Method.
5. Press the CHANNEL UP button ((or POWER or PLAY (VCR only)) repeatedly until the device to be controlled changes channel.
6. Press and release MUTE to install the code.
Note, when all modes under a Brand have been searched the red indicator flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying "Direct Code Entry" or "Code Serch (by Brand)" your device does not respond, or if your brand is not listed, try doing a device search of the code library for your code by following the steps below.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until lhe red indicator stays on, then release the CODE SEARCH button.
3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
5. Press and release MUTE to install the code.
Most users will want to store VCR codes under the VCR button, Cable codes under Cable, etc. If you want to store a VCR code under Cable, etc., first follow the procedure for Direct Code Entry and press Cable in step 2 of Direct Code Entry then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Brand Search or Complete Search.
Brand Search Table
Look up your brand in the appropriate column TV, VCR, elc.) in the table below. Look for the digit (1, 2,3, etc.) that applies lo your brand, and enter it in step 4 of "Code Search (by Brand)."
moz-scPhilips PM435S 4-Device Remote Control - moz-screenshot-1.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpg
Posted on Dec 15, 2007
2 Related Answers
Anonymous
  • 23 Answers
SOURCE: Philips universal romote pm435s code and manual
try those codes: 0023, 0223, 1112, 1912, 1515
Posted on Oct 15, 2008
muebe
  • 1015 Answers
SOURCE: I have an Philips Magnavox PM435S 4-Device
You can try these codes: 0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598
Also try these: 0330, 0430, 0534, 0324, 0224, 0124, 0230, 0125, 0247, 0093, 0598, 0830
See which one works best.
Posted on Jan 13, 2010
Need codes for a philips pm435s
http://www.urc.philips.com/ This link will take you to the Philip Support site where you can download manuals and code sheets for free.
Mar 19, 2009 | Philips PM435S Remote Control
Program codes
http://www.urc.philips.com/ This link will take you to the Philips Support site where you can download manuals and code sheets for your remote.
Mar 15, 2009 | Philips PM435S Remote Control
Oct 14, 2008 | Philips PM435S Remote Control
Need help with the Philips PM435S Remote control
philips codes supported by the remote are: 002 009 020 109 122 202 209 210 222 310 322 402 408 422 508 510 807 822 901 914 917 919 922
programming instructions:
1) Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2) Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3) Enter the 3 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4) With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
hope this helps,
trin
Nov 16, 2007 | Philips PM435S Remote Control
I have a pm435s, 4 device philips universal
Here are the 4-digit codes for my 4 device Philips Universal Remote. It is in pdf format. I have also upload the manual so you can punch forward features, if needed. See the comments at this link. ====>
http://tv.manualsonline.com/ex/thread/view/idThread/549512#comments
Oct 17, 2007 | Philips PM435S Remote Control
Philips PM435S Remote Control Logo
4,816 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
