Question about Ricoh Office Equipment & Supplies
Aficio SP C820DN. How should I respond to error code SC360?
Posted by Mayowa on
Freckled legs
    Habit-Forming:
    Scholar:
  • Ricoh Expert
  • 129 Answers
  • TheVt value of the blackTDsensor exceeds the specified value (default: 4.7V) with SP3020-002 for twenty counts.
  • The[Vt-Vtref]value of the black TD sensor exceeds the specified value (default: 5.0V) with SP3020-001.
  • Push the decal (three green lines) attached to the lever using your finger, for all four PCDUs.
    Check the pentagon-shaped window for all four colors. If you can see a red area, as shown in the "Incorrect" photo below, this means the unit was not installed correctly.
    Make sure that the white locking tab on the PDCU (circled in red below) is inside the hole of the bracket. Do this for all four PDCUs.
Posted on Feb 25, 2016
Sp c820dn laser Printer error sc561 problems???
Replace the fuser. Then thermopile if it continues.
Aug 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
What is sc 565 on a sp c820
SC565
*Heat lamp consecutive on error
- Broken main fuser connection
- Check HR thermistors
- Heat roller lamp defective
- Power Supply defective
May 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
Service call 582
This error is a fuser error .
The fuser is not set properly,remove the fuser and set in properly if the problem persists, fix in a brand new fuser.,
If the error appears again then call an expert to check on it for you.
Good luck
Apr 09, 2014 | Ricoh Aficio SP C820DN Laser Printer
ERROR code sc582
problem thermofuse heater stove
Jan 14, 2014 | Ricoh Aficio SP C820DN Laser Printer
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
Sc582
tengo un problema con la maquina ricoh sp c820 el error es sc582
Sep 24, 2010 | Ricoh Aficio SP C820DN Laser Printer
192 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
