Question about Garden
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
3 years old. cutting grass it stopped. cooled down, it stopped again in 4/5 seconds.Cooled down,it Stopped again after 4/5 seconds. Next day, Opened handle/button assembly no damaged wires or displaced wires. Switch block wired OK. Small, white block, tiny 'starter motor'? Wires OK. Full length main cable no damage. Cover off the motor. No damaged/disconnected wires. Started machine again & stopped after 4/5 seconds, AGAIN! Do we need to buy a new mower?
Posted by John Humphries on
L Pfaff
    Top Expert:
  • 11,573 Answers
Check gas cap for proper venting, will it run better with cap off.
Posted on Feb 15, 2016
Why does our Bosch 32R mower keep cutting out?
is this a corded mower or battery operated . if corded your cord might need replaced
Feb 13, 2016 | Office Equipment & Supplies
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
I have a cub cadet 1000, it's approx 4 years old, i was in the middle of cutting the grass and the mower stopped running. Tractor runs mower will not come on. Is there a switch or module that nee
check the clutch on the end of engine drive shaft it is the same as a car air con clutch put power on to it and it should click so most likely the wire from switch to clutch
Apr 22, 2013 | Cub Cadet Garden
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Vitamix 5000 suddenly stopped working
As the override gizmo will not reset when cooled down you do know that it is faulty so replacing it is going to have to happen anyway if you are repairing it. It may be just that item that's gone bad or it may have been made bad by the motor drawing excessive current. The proper way to check current draw would be by running it through an ammeter. The last thing you want is a faulty motor, they cost a fortune.
Dec 19, 2017 | Vitamix Super 5000 Work Top Blender
My rider stopped in high grass, would not start.
first must by the connection bettw.battery and starter.second mesure short cut of the starter .try cu see if you have the seal battery or not.in this case try to see if there is mixture water + acid(enough) on it.other solution -you have broken battery charger relly.
Sep 11, 2009 | Garden
Won't start after running for some time
check the oil in it some of the new mowers have a low oil shut down switch on them so engine doesn't blow up the other thing you can try is sprying carb. clean in carburator try these & let me know , wade
Jun 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dead microwave
check mains fuse and check control circuit and magnetron. and diodes capacitor  high voltage related circuit. small part also gone microwaveoven doesnot works, first check oven and conform which part was spoiled, after that this is worth or not old ovens good compaare to new ones...
Oct 25, 2007 | Panasonic NN-T888S Convection/Microwave...
Garden Logo
342 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
