How to reset or solution
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
SOURCE: Brother Laser HL-5240 has a status light and toner
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
SOURCE: Brother HL-5240 all lights are on
i got hp officejet j4580 all in one and on the screen its saying to trouble shoot but dont know how
SOURCE: Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following
steps.
2. Turn the printer off.
3. Hold the 'go' button while
turning the printer on. All panel lights should be on.
4. Release the
'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7.
Press the 'go' button 5 times.
8. The toner light should be off.
9.
The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready
light should be the only light on.
SOURCE: My Brother HL5250DN shows toner light on (yellow)
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
