Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
How do I order new trippers? - Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Posted by don pearson on
Intermatic troubleshooting
You need new 120V WG1570 clock motor
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
Order extra trippers too... motors and trippers are replaceable so timer can last 25+ years
http://waterheatertimer.org/Buy-T100-series-timers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 27, 2014 | Intermatic Hardware & Accessories
Ti04 clock rotates and new trippers but doesn't turn on
You probably have T104 timer.
Clock rotates so power to timer motor is good. This means 240Volt breaker is good.
Use override lever and see if Load (light, fan, motor) turns on and off. If override does not turn Load on-off, then bypass timer and see if load works. Move wires from terminal 2 to terminal 1, and terminals 4 to terminal 3.
Did you order correct trippers?
Copy following links for Intermatic troubleshooting and Intermatic parts list.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
I installed a new T104 m for my pool pump. The clock works fine and it works fine manually. The on and off stops do not turn it on or off. The clock goes right past the on and off stops and they don,...
You installed new 240Volt T104 Intermatic timer.
Cause of problem is not determined, so read information below and then add a comment with further observations.
According to question:
Timer is wired correctly.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
The on-and-off trippers are installed on dial, but do NOT click the override lever back and forth.
Both ON and OFF trippers are on the dial.
And the timer is NEW and not used, and trippers are NEW and not used.
And the dial rotates and keeps good time, making 1 full rotation each 24 hours.
And the manual override lever works and turns load (pool pump) on-and-off.
Open following link to view photo image of OFF tripper coming in contact with manual override lever.
Trippers are soft metal, and made to wear down. When tripper gets old, it will slide over the lever instead of move the lever.
http://waterheatertimer.org/images/WH-lever-005-500.jpg
Open following link to read how to set timer, and see close-up images of timer with trippers on dial, and tripper order number for replacement trippers.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I have lost plastic pin{red} for my indoor light timer. Is there anything I can use to replace it,or can I buy a new one? If so where can I get them? It is an INTERMATIC TIME ALL Model No. TN111.
Open following link for Intermatic trippers and parts with identifying numbers and ordering information.
According to Intermatic information, TN series uses 107TN222 turquoise ON tripper, 107TN221 red OFF tripper.
Order from Intermatic:
http://store.nexternal.com/intermatic/categories.aspx?Keyword=107TN221+tripper&x=20&y=13
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 03, 2011 | Intermatic Hardware & Accessories
I have a Tork 1101. Please advise how to set the OFF time.
Tork 1101 is 24-hour 120Volt mechanical dial timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
Dec 09, 2010 | TORK Hardware & Accessories
I've set the time on/off and ive tried turning on manually but the lights wont turn on on exact time set. y? when i manually turn on the lights come on 2 hrs later or so, y doesnt it turn on right away?
If I understand correctly, you have an Intermatic timer.
The timer has a yellow dial that rotates around like a clock.
Does the manual override work?
If yes.
a) then the circuit has electricity
b) the lights are in working order
Does the clock rotate?
If yes
a) then the timer is probably good
b) the clock motor could be bad
c) the gears could be rusty and dirty
Do you have the current time set correctly?
Lift and rotate dial until current time lines up with silver pointer.
Do you have the trippers set on the correct time?
There are ON trippers and OFF trippers
Attach trippers to correct time
Tripper pins wear out
Suggestion: You sit in front of the timer and watch the trippers as they rotate to the bottom of the dial
When the trippers get to the bottom, they push a lever that turns lights on and off.
Look at the photo:
Here's a website that sells tripper pins and clock motors for Intermatic timers.
You can buy new trippers or clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Answer this post if you still can't figure out the problem, or need more help.
Oct 23, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have lost the little plastic pegs that turn the time on and off can you tell me where I can buy them.. Home Depot and Osh do not have them
According to Intermatic literature, ML series Power Pack uses 107SB189 ON tripper, and 107SB192 OFF tripper. I have not ordered these trippers and no image seems available.
Red On tripper available at IntermaticStore.com
Black Off tripper available at IntermaticStore.com
Tripper order form
For more information on power packs:
http://www.fixya.com/support/r8391011-power_pack_not_working
Jul 08, 2010 | Intermatic Malibu 300W Power Pack...
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
174 people viewed this question
Top Paragon Hardware & Accessories Experts
jdthefixer
Marvin
Marvin
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
