Question about Rival Food Slicer
Need a blade retaining nut - Rival Food Slicer
Posted by gary gillis on
Larry Allin
    New Friend:
  • 26 Answers
If you need the grey plastic type, I can't help; but, if you need the metal type, I probably can. I normally stock recycled threaded shafts and thumb nuts for old Rival and Magic Hostess metal-framed (not folding plastic) slicers. I also have new rubbers suction cup feet and friction-reducing blade washers.
need a blade retaining nut - need-blade-retaining-nut-1da0kn30pxowr0ebacrfmmyb-4-0.jpg
Posted on Jun 02, 2016
Change blade on Briggs & Statton engine
Hold blade and loosen bolt. If you have a impact use that. If not hold blade tight and loosen the bolt.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Jul 13, 2016 | Garden
How do i adjust a chainsaw
I like to loosen the blade quite loose, then hold the saw by the blade and tighten the blade retaining nuts. This puts the right amount of tension on the blade without making it too tight.
Aug 25, 2014 | Garden
Need to replace a miter saw blade on Black & Decker saw
If you don't have a manual, you can contact Dewalt, and they will get you one or help you. UNPLUG THE SAW!! , if your saw has a blade lock, engage it, if it doesn't hold the saw firmly on a scrap piece of wood. Then use the correct wrench and loosen the retaining nut. Take the nut off, remove the blade
Feb 24, 2014 | Black & Decker Saws
How do I change my blade? I lost the manual. it has a guard and when I try to loosen nut it cant come all the way out cause the guard is there
Generally, depending on the manufacturer, the nut only has to be loosened and then looking from the blade end you will see a slotted screw. Turn the screw counterclockwise while wiggling the chain bar until the blade is loose enough to remove from the guides. You may have to put a small flat screwdriver under the retaining nut and pry up lightly while loosening the nuit with a wrench or socket..After backing the nut off enough the blade bar should slip up and away from the drive gear.
Apr 03, 2011 | Garden
Can't get wiper blade arms off. need replaced
lift the arm away from the windshield. if the tension spring is damaged or broken, the arm will not show
resistance. if it is working properly, then pull the arm back until the hinge locks in a verticle position.
remove the retaining nut at the bottom of the windshield wiper arm and pull the wiper arm off.
slide the new wiper assembly on.
tighten the retaining nut and lower the arm back down to the windshield. you will need a wrench and
socket set. good luck!
Jan 23, 2011 | 1999 Chevrolet Silverado 1500
My new toliet seat dosent seem to screw on properly its all wobblerly its going from side to side
You probably just need to tighten mounting screws. Most screws are covered by a cap or cover that snaps into place. You should be able to unsnap the cover with a small blade screwdriver or knife point. Use a wide blade screwdriver on the slotted head screw on top to tighten while holding retaining nuts on the underside of toilet. Some of the screws and nuts are plastic so you should be able to hold the nuts by hand while using screwdriver to tighten screws. If you can't hold nuts by hand use pliers. Some use brass screws and nuts so use proper size wrench to hold nut. Hope this helps you. Thanks
Nov 22, 2010 | Home
How do I change blade non model 2708 table saw?
You should have a stamped metal box-end wrench that came with the saw. Place it over the blade retaining nut, and drive the motor belt by hand to allow the wrench to tap on the table behind the blade. This will loosen the nut so that it can be removed by hand (this is a left-hand thread situation). Tightening the nut is the reverse operation and it is not necessary to drive the nut tight with a hammer--it will tighten enough during saw operation. A safety manual will say to remove power from the machine when doing this! Hope this helps!
May 24, 2010 | Saws
How do I remove the windshield wiper motor from a Ford F-250?
2002 Ford F-250 Windshield Wiper Motor Removal & Installation 1. Turn the ignition switch to the ON position. Turn the ignition switch ON until the wiper blades are straight up, then turn the ignition switch OFF. 2. Disconnect the negative battery cable. 3. Remove the right-hand and left-hand windshield wiper arm and blade assemblies. 4. Remove the cowl top vent panels. 5. Detach the electrical hardness connector at the windshield wiper motor assembly. 6. Remove 3 wiper motor (module assembly) retaining bolts and remove the module assembly from the vehicle. 7. Remove the wiper linkage retaining bolt and remove the linkage from the wiper motor. 8. Remove 3 retaining nuts and remove the windshield wiper motor To install; 9. Place the windshield wiper motor in position and install 3 retaining nuts. Tighten to 10-12 ft. lbs. (12-17 Nm). 10. Connect the wiper linkage to the windshield wiper motor and install the retaining bolt. Tighten the bolts to 14 ft. lbs. (20 Nm). 11. Place the wiper motor (module assembly) in position and install 3 retaining bolts. Tighten the bolts to 6 ft. lbs. (9Nm). 12. Install the electrical hardness connector to the windshield wiper motor. 13. Connect the negative battery cable. 14. Allow the windshield wiper motor to cycle several times while checking for proper wiper motor operation. 15. Turn the windshield wiper motor to the OFF position to park the wiper motor in the park position. 16. Install the cowl top vent panels. 17. Install the wiper arm and blade assemblies. Install the retaining nuts and tighten to 22-29 ft. lbs. (30-40 Nm). 18. Connect the negative battery cable. 19. Check the windshield wiper motor for proper operation and the wiper arms for adjustment.
Nov 09, 2009 | 2002 Ford E250
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Rival Food Slicer Logo
942 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
