Question about HP Deskjet 3510 e-All-in-One Printer
Keeps saying cartiage jamed - HP Deskjet 3510 e-All-in-One Printer
Posted by Evelyn Griffin on
Davy Smith
    Habit-Forming:
    New Friend:
  • 74 Answers
Use a cotton bud with alcohol to clean the runners that the cartridges travel on
Posted on Mar 06, 2016
New cartiage not recogized
faulty cartrige take it back and get another the gold strip has a defect and printer wont pick it up
Mar 27, 2010 | Dell 924 All-in-One InkJet Printer
Why wont the print when you put a new color
check the cartridge expiration date, and be sure that it is genuine
Mar 22, 2010 | HP DeskJet 2600 InkJet Printer
Ink cartiage not proparly install but my ink cartiage refil
ink cartiage not properly installed ae shown but my cartiage are riffil
Jan 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer cartiage error
This page may help.  One of the things it's supposed to help with is 'cartridge error'.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00094661&dlc=en&product=374581
If that doesn't help, can you provide more detail about the cartridge error message?
Dec 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
Toner cartiage and drum replacement
Go to menu to reset drum settings. I think you leave the front cover open press the right arrow then 1 one the lcd shows replace drum then after the lcd says accepted close the front cover.
Dec 18, 2007 | Brother MFC 9700 All-In-One Laser Printer
New cartiage/not reconized
It says there is no cartridge, or does it say that the cartridge is empty?
First, you must realize there are two cartridges. A drum and a toner. If you bought a new toner, pulled out the drum and put the new toner in, you have pulled a DOH! You can't just put the toner in. You have to take your old drum cartridge, remove the toner portion and install the new toner into your old drum and then install the entire assembly back into the machine. I hope you didn't throw your drum out thinking it was all one cartridge (I've seen it happen). This is where reading the owner's manual helps.
If not, then one of the contacts must have been damaged. Remove the cartridge and look inside the machine. See if you can find any of the metal contacts on the side of the inner chamber that is bent or damaged and try to bend it back.
Check the drum and make sure none of the contacts are damaged.
If the unit is still saying Toner Empty, try this. On the left side of the toner there will be a while lever in a semi-circular notch.
Unplug the unit, use a small screwdriver or a key to push that white lever back to the front of the notch. Put the drum and toner back into the machine and plug the power back in.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
Paper jam
i have an hp office jet 5510 and its not print and it keep on saying cartiage is jam , the timeing is all mess up the leg that bring the paper out keep on coming up whilethe cartiage is going across is there a way of reset the print to get back the timeing
Nov 01, 2007 | HP Officejet 5510 All-In-One Thermal...
I had the same problem too. Brand new unit and 5100 error comes on after power up. There is nothing jaming the ink cartiage, and it only moves a little bit to the left then jams back to the right. I can't even load in new ink cartiages. It's going back to the shop today.
Apr 23, 2007 | Canon PIXMA MP170 All-In-One InkJet...
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
