Washing Machines Logo
Wilma Campbell Posted on Feb 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool keeps stopping with fh coming up with red light saying water tap closed what does that mean
Chris Huff
Level 3:
Top Expert:
  • Whirlpool Master 6,289 Answers
  • Posted on Oct 15, 2018
Chris Huff
Whirlpool Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017839
Points
74913
Make sure both hot and cold water supply valves to washer are turned on. Make sure they are not reversed. Check fill hoses to washer for kinks or clogged screens at water inlet valve. The manufacturer has assigned this error or fault code to indicate that there is a problem with the amount of water entering the machine.
Steve Luck
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 819 Answers
  • Posted on Feb 11, 2016
Steve Luck
Master
Level 3:
Dedicated:
Answers
819
Questions
0
Helped
218680
Points
2252
My whirlpool keeps coming up fh and red light comes and water tap closed what does this mean
if you lift the top of your unit you will find the paper work for repairs in there and also has the code sheet.
1helpful
My whirlpool 6th sense washing machine keeps saying water tap closed half way through a cycle and displays FH what dus this mean?
That's a water filling problem.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Whirlpool awm 8103/s keeps stopping during cycle with code FH displayed? any suggestions
Whirlpool's 'FH' stands for 'no water inlet' (but goodness knows how 'FH' could mean that!)
John C
1helpful
We have an AWM8143 (German Made ) whirlpool front loader. The machine stopped during a wash just before the rinse cycle and is coming up with 'FH' fault on the display. The windows on both inlet...
The 'FH' fault is listed as "Water Inlet Fault" in the manual. When the windows in the inlet hoses come up with their red dots, it means that the leakage valve has tripped and shut off the water at the tap. No water will flow into the machine. This can be confirmed by first turning the taps off, then taking the hoses off at the machine end. While holding the loose ends of the hoses over a trough or sink, try turning the taps on. No water will come out. I've had the same thing happen to us. We were quoted $66.00AU per hose for replacements. I'm going to try to fix one of these hoses today. They have a sponge in them which expands when it gets wet and shuts off a valve. I'm going to try getting the sponge very wet and squishing it back down and hopefully opening the valve again. Hope this helps.
1helpful
The machine displays FH, what does this mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Whirlpool washer duet
The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
Water tap closed
The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
1helpful
Water tap closed led illuminated also FH in time remaining
traced the fault to the cold water valve solenoid not operating so pleased to say that the person that sold me the washer has now given me my money back
regards paul
2helpful
2answers
WFS1071AW is my type of whirlpool front loader
Hello baud Welcome,
You said the water entry into the machine is fine with nothing blocking it. But you keep getting the red light on for "water tap closed". At one point the water did start flowing in but soon stopped and turn on the warning light again. Please suggest how to fix it??
I believe this sounds like the screens are dirty and stopping water flow so it shuts down!
Dry all of the below suggestions.
Washer displaying code message and or tone sounds
“F20” (Water Inlet Problem—no water or insufficient
water supply)
First:
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.Leave power off for 5 minutes. This will reset the system!
Check the following:
Are water faucets completely turned on?
*****Are screens at inlet hose connection to washer clogged?
Remove hose from washer an clean screens at water inlet!
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Let me know how you do.
Thank You Huuum
Please remember to leave a rating!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
