Question about Dell 1720dn Laser Printer
My dell drum wont reset even though i bought a new dell drum? any suggestions?
Posted by Wanda Lewis on
I needed a new drum (j2 error) so I bought one, installed it correctly, but the machine still shows the j2 error and will not clear itself or let me make copies. What can I do? I really need it to be...
Found old post for diffrent printer see if this info helps.
Drums may worj the same even though diffrent models.
Problem with the Xerox Printers Xerox XD130DF J2 error replace
By lgrey on Jun 20, 2008
Xerox XD130DF J2 error replace drum Best Solution posted 3 years ago
cbb7438.jpg rytech uk
  • Rank: Wiz computers_small.png
  • Rating: 80%, 98 Votes
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
Jul 06, 2011 | Xerox WorkCentre XL2140df Laser Printer
I just bought a new ACER desktop computer OS Windows7 and I cannot install Dell Photo All-In-One Printer 964 Free Download even though I bought the printer from you and have been using it with my Dell...
Even though I don't work for Dell, maybe I can give you a few ideas. Did you make sure that the download you tried was Windows 7 compatable? Also this might be a silly question, but I've actually done this before. Did you install the printer on your ACER?
May 21, 2010 | Dell Photo 964 All-In-One InkJet Printer
Dell computer was working and i turned it on next day and it was dead no lights or noyhing
If your computer is under warranty, I'd suggest you contact either the Vendor where you bought it, or the Dell support site. Either should be able to acquire a new power supply and install it for you free of charge (if under warranty).
Some other thoughts though, before you do that. If there are no indicators that your power supply has died (smell burnt electronics, any weird buzzing sound prior to the computer not working, etceteras), then you might want to check the connections to the wall socket, the connection to the PSU itself, and even test the circuit breaker for your socket (some wall sockets have test / reset buttons that cut the power during surges).
-Jon
Sep 26, 2009 | Dell POWER SUPPLY Power Supply
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
I have a MFC-8660DN that is not even three years old yet. I just replaced a toner cartirdge in the drum for the second time. The window shows red and says to reinsert the drum( not replace it). I bought a...
When you replaced the drum did you reset the counter as per the instruction sheet with the new one? I think from memory you hold the OPTION button with the door open. This gives the option of resetting the count in the display.
Good luck these are usually very reliable.
Al
Feb 28, 2009 | Brother Office Equipment & Supplies
Dell 1600n all in one printer cartridge drum problem
the drum is a part of the toner in this model. Replacing the toner should resolve the issue.
Feb 17, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
Photocopier 7013
You must reset in his menu! Go in setup menu or status menu and there must be reset Drum unit!!! But it's not the same cartridge and drum unit!!! It's separate part's!!! Give me exactly message!!
Jan 30, 2008 | Office Equipment & Supplies
Dell 1720dn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
