Question about Samsung Galaxy S6 Edge
How do I put a voice message on my phone when I am not available to take the call
Need to leave a voice mail
Eddie Tam
  • Samsung Master
  • 284 Answers
Samsung Galaxy S6 Edge: How to put a voice message on phone when not available to take call:
Hello. If you did not set up your voicemail account yet..
Simply, on your S6 call your own phone number. When you do this it will ask you to set up your outgoing voice message.
Setting up Visual Voicemail
Visual Voicemail Samsung Galaxy 6 edge G925T
Posted on Feb 10, 2016
Does my phone have a voice mail option?
Most hard line phones do not have voicemail option people just leave a message for you .
Dec 21, 2015 | Big Button GE 29369GE1 Speakerphone
Voice mail not working
The Voice Mail system provides the voice mail service based on the existing network. When a call is transferred to the VM system, the system asks the calling party to leave a message for the called party when the called party is busy, powered off, or out of the service area. It provides voice mail, call prompt, and voice short message and email. By adopting VM service, operators' system put-through rate, service usage rate, customer satisfaction, and revenue can be improved.
Aug 20, 2013 | Panasonic KXDT321 Phone
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
Aug 09, 2012 | Panasonic KX-T7630 Corded Phone
Lost the manual and need to record a new voice mail message
to leave a voice mail message on the Samsung Prostar;
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
Jan 22, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
When someone calls me the ringer on the phone does not ring.I do not know how to turn the ringer back on. Also when someone tries to leave me a message the answering machine does not record the message....
On the phone not ringing, just push the volume up button while the phone is not in use, that should adjust the ringer volume. As for the message saying that calls are being routed to an automatic message sertvice, that sounds like a voice mail offering from your service provider, not the phone. Uniden phones have a default greeting that says "Hello, no one is availible to take your call, please leave a message after the tone" Contact your service provider and find out if you have voice mail service on your line. If you do and want to use the answering machine on your phone, you will need the service provider to allow for more rings before the voice mail service takes the call.
Mar 16, 2009 | Uniden 5.8GHz Dual Cordless Phone
Can not set my voice mail on my LG Vu phone
what you do is go to menu and then hit the button that says messaging (the envalope) (sorry if im explaning this so simply i just dont know if you know how to work the phone) the go down to the one that says VOICEMAIL and hit that (well not hit it just you know, poke it or select it :) it should then dial your voicemail. It then should say ....TO CHANGE YOUR PERSONAL OPTIONS PRESS 4 (then open keypad and press 4) then it should say... FOR GREETINGS OR RECORDED NAMES PRESS 3 (onen kepad press 3) then it should have different options such as just one with your 1. name (bob is not available leave a message after the tone) or 2. your number (123-456-7890 is not available please leave a message after the tone) or 3. a personal greeting where you can record whatever you want (hi i am not hear blah blah blah leave a message blah blah blah)
Feb 08, 2009 | RIM BlackBerry Pearl 8100
Finding out day/time someone leaves voice mail?
listen closly at the beginning it tells time and day
Sep 12, 2007 | Motorola Mobility E815
Samsung Galaxy S6 Edge Logo
129 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
