SC 672 is a controller error. So possible is tat the controller board is defective, in best case can be only the ram memory dimm's or the HDD but in most cases the controller board is dead.
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
High voltage leak
Broken harness
Defective drum unit or development unit
Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
SC866 B SD Card Error 1: Confirmation The machine detects an electronic license error in the application on the SD card inserted in the controller slot when the machine is powered on. The program stored on the SD card contains electronic confirmation license data. If the program does not contain this license data, or if the result of the check reveals the license data in the program on the SD card is incorrect, then the checked program cannot execute and this SC code is displayed. • Required program missing or incorrect • Download the correct program for this machine onto the SD card. SC867 B SD Card Error 2: SD Card Removal The SD
