First of all, is there a green power light on the control panel, if not check that the main power switch is on, located at the right side lower right. Check that the main circuit breaker hasn't been blown on the copier. If these are good, turn off the main power switch and back on again. Look on the display to see if there is a progress bar on it. This is booting up the copier and if all goes well it will come to ready. If not it will give you an error message and then I will have to know what that is help any more.
This error on the Canon iPF-605 wide format printer means that there is a problem with the paper cutting knife. The knife (black block) should be at the left front side in it's rest position.
Powered the printer down and moved the knife block from right to left, powered on and voila: problem solved ! Thanks Canon support!
a) How to enter Service mode Follow the procedure below to enter Service mode. 1) Turn off the printer. 2) Turn on the printer while holding down the [Paper Source] button and [Online] button. 3) Check that "Canon W8200" is shown on the display, and then release the buttons. 4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will be displayed after the sheets are loaded.) 5) Use the [Lower arrow] button to make a selection. Service mode is added to the options in the Main menu. Service mode can be entered even during error status (when Exxxx and Wxxxx are shown on the display) by turning the power off and then using the above key operation. b) How to exit Service mode To exit Service mode, turn off the printer. c) Buttons used in Service mode • Selecting menus and parameters: [Left arrow] button or [right arrow] button • Entering a lower-level menu: [Lower arrow] button • Entering a higher-level menu: [Upper arrow] button • Setting menus and parameters: [Enter] button
Now under service mode select counter, and select printer and W-INK to reset it, and under initialize select W-INK. But also change the waste ink absorber so that you do not get waterfalls of ink from your plotter :-)
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below. - E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.) - E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable). 2. Turn ON the main power switch. 3. Change the setting values of the following service mode items. - Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'. - Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'. Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1. - Color Image Reader-E1: Platen cover model - Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1) - Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180) 4. Turn OFF the main power switch, and connect the DDI cable. 5. Turn the main power switch ON. Note: How to turn OFF the main power switch. When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine. 1. Hold down the control panel switch for 3 sec or more. 2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.) 3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Main cause The cable connector has poor connection. The reader controller PCB is faulty.
Condition 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB.
Connectors
1) Connect the cable [1] for the environment heater.
2) As needed, connect the reader unit anticondensation heater cable [1].
actually ink absorber is full means you printer inside got small pieces towel to absorb ink. but Canon PIXMA printers display an error when a certain internal counter
suggests that the ink absorber may be full. If you've done a lot of
printing, the ink absorber may actually be full and you might need to
have it cleaned or replaced to ensure the best printing quality.
However, if you haven't printed that much or you have and you just need
to print something right this minute, there is a way to reset the
counter and stop the error from showing up again
please try go to this website : http://ij-forum.blogspot.com/2008/09/how-to-reset-ink-level-of-fine.html the you go left hand side download General Tools (EEPROM Resetter) Collection and install on you cpu.
after download remember to turn on printer before install it.then go to Reset ink counter by clicking Reset main on waste ink counter menu
try this if can't i think you need send to shop for technician to open it and clearning for you....
